Celsius to Fahrenheit ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by limitedlifted, Jul 27, 2016.
  1. Sep 17, 2017 at 6:25 PM
    #101
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Hey OP... what year and model of truck are you talking about?? That might help..
    I know that on my 2016 sport, I can change the speedo to Miles or KMS....... the MPG will use US or Imperial gallons to calculate the MPG's. I'm sure the Temp would be available also.....
    Does your truck show speedo in Miles now..?
    I was reading pg. 96 of my manual and it says I can change the units of measure for fuel consumption and temp. It tells you how to do it on pg 95....
    If you have a different truck.... read the manual, I guess..
  2. Sep 18, 2017 at 6:41 PM
    #102
    JukemJake
    JukemJake Active Member
    Jacob
    Kent, WA
    2017 Red Toyota Tacoma TRD Sport
    Goodyear MTRs with Kevlar (285 70 17) SCS Ray 10 Wheels 3" level lift Vision x grille lights
    Yeah if you have the Canadian truck, the interior air will always be in C. I went to dealership and outside changing the ECU, if that even works, we will always have it. I just multiply by 2 and add 30. Its close enough to get in F (I know it's not the exact formula but it's close)
  3. Sep 18, 2017 at 8:01 PM
    #103
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Man, you guys are complaining about nothing! When I was seven years old, my family moved to England for 6 months and I had to go to school there. Typical English school math word problem in 1964:
    "Little Jimmy goes to the confectioner's and asks for two bob's worth of gobstoppers. He hands the confectioner half a crown. How many farthings will little Jimmy get in change?" And WTF is a gobstopper? And, getting back on Tacoma topics, what's the payload of a 3rd gen in cwt?
    ancient11 and Hank Heel like this.
  4. Sep 18, 2017 at 8:13 PM
    #104
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    :confused:
    I'm confused.
  5. Sep 19, 2017 at 4:37 AM
    #105
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Lol we grew up with gobstopers. A large round hard candy with many layers of colours and flavours. Haven't seen them is many years.
  6. Sep 19, 2017 at 6:33 AM
    #106
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Thanks for explaining that.
    Steadfast[QUOTED] likes this.
  7. Sep 19, 2017 at 9:14 AM
    #107
    derby
    derby Member
    gobstoppers are jawbreakers in the states.
    Pittrider likes this.
  8. Sep 19, 2017 at 11:28 AM
    #108
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
  9. Sep 19, 2017 at 6:42 PM
    #109
    over60
    Muskoka, Ontario
    I tried to change the readout from C to F in my CDN truck.....NO GO. I can change the outside temperature, but not the heat/cool controls.!!
  10. Sep 19, 2017 at 6:50 PM
    #110
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    You need carista or techstream.
    over60[QUOTED] likes this.
  11. Feb 27, 2019 at 4:26 PM
    #111
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    Have you ever figured out how to change the unit from C to F?
  12. Feb 27, 2019 at 5:46 PM
    #112
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I enjoy setting the rental vehicles I drive in the US to metric, then leave it at that when the car is returned. (Just make sure you are on an unlimited mileage contract, otherwise they get the last laugh.)
  13. Oct 17, 2019 at 11:10 AM
    #113
    Hitch001
    Hitch001 New Member
    So my vehicle is Canadian and has a software update available but I can not download it because I am not in Canada. Is there anybody out there in Canada that could download the updat and send it to me.
  14. Oct 17, 2019 at 12:18 PM
    #114
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Send the link, and I can see what can be done.
  15. Oct 18, 2019 at 12:32 PM
    #115
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This was a fun thread, haha.
    As far as I am aware, the only way to change the climate control display from Celsius to Fahrenheit is to change the main body ECU.
    Not verified.
    Jeff
  16. Oct 19, 2019 at 9:56 AM
    #116
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    For speed measurements, I prefer Furlongs per fortnight.
    (Sorry, couldn't resist.:rofl:)
    RapidRoy likes this.
  17. Jan 25, 2020 at 6:38 AM
    #117
    RapidRoy
    RapidRoy Well-Known Member
    1999 3.4L SR5 4WD MT
    Haha! I don't think I've ever posted, but this thread cracks me up. I had a physics professor in college who thought it would be funny to put a question on the test that asked people to convert a number in Furlongs per Fortnight to Meters per Second. About half the class looked at it and knew it was a joke because they understood the wacky professor. The other half of the nerd herd couldn't relate to people, so didn't understand the professor, and didn't get that it was a joke. They freaked out, thought the question was unfair, protested loudly after the fact... Some even wasted a bunch of test time trying to figure it out--which is exactly what this thread seems to be doing.
    More to the important issue of using Furlongs per Fortnight for a speedo, Furlongs per Fortnight are totally impractical. If your speedo is 0 to 140 mph or 0 to 220 kph. Your speedo in Furlongs per Fortnight would go from 0 to 376,320 fpf. So you're just being silly!
    Oh, and I forgot to mention that I just bought a Canadian Tacoma and would like to change the heater/ac temp gauge to Fahrenheit. Sounds like it is hard coded in the ECU or temp readout. I guess I'll just have to print up a label that says "multiply by 9, divide by 5, and add 32 to set your proper comfort level". I'm sure my wife will appreciate my thoughtfulness. Now that I think about it, the label idea is perfect. She's normally on the temp control like a monkey on a cupcake. This might just slow down the constant changes from hot to cold to hot to... By the time she gets the calculator out and decides what the temp should be, she'll want it a different temp and need to start over.
    TeecoTaco, VE7OSR and Tacorific like this.
  18. Jan 25, 2020 at 6:44 AM
    #118
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    My Tacoma gets 40 rods to the hogshed and that's how I like it!
    Jeff Lange and Grindstone like this.
  19. Jul 12, 2020 at 10:32 AM
    #119
    Knuckledragger
    Knuckledragger Well-Known Member
    Plymouth, MN
    2016 DCLB. 2003 xtra cab (sold). 5th Gen 4RSR5P (sold)
    yeah. I just bought a Canadian truck. Has anyone figured this out yet?
  20. Jul 12, 2020 at 6:41 PM
    #120
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    My neighbor uses both units when he talks...the other day he was saying how in the the sun it was like 100 degrees Fahrenheit and in the shade was only 25 Celsius...
