Cement Color and Scratches?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Offroadr, Sep 18, 2020.
  1. Sep 20, 2020 at 1:12 PM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    I'm a big fan of spray on detailers. Mothers makes a good one but I'm going to try out Chemical Guys next because I've been thrilled with the rest of their products. Basically grab you a bottle of your choice and two microfibers that are different colors. Spray on, use one towel to wipe/spread and let it dry to a haze. Use your other towel to buff the haze until you can't see any leftovers. Make sure to look at different angles because head-on may look great but you look from the side later on and end up cleaning off streaks with your shirt. Try to avoid doing it in direct sunlight if possible because it will dry extremely fast and be difficult to remove. If that does happen take your wet towel (the one you used first) and wipe it down and immediately follow with the dry towel and repeat as needed. These spray on detailers also work well with clay bars. Also avoid anything made by Armor All.
    Oh also if you're trying to remove surface scratches this process will need to be repeated several times with a bit more elbow grease.
