Cement Cost
Discussion in 'Garage / Workshop' started by 4x4jeep, Jan 5, 2012.
  1. Jan 5, 2012 at 5:53 PM
    4x4jeep
    4x4jeep [OP] Well-Known Member
    Kyle
    Destin FL.
    Does anybody know a ballpark cost for 11 cubic feet of cement? Located in Florida but just trying to get a ballpark figure. Thanks Kyle
  2. Jan 5, 2012 at 5:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You gonna add the navvy jack and water on site ?
  3. Jan 5, 2012 at 5:58 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    WTF is is navvy jack ?
    I know, secret Canadian code again.
  4. Jan 5, 2012 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    Gravel and sand mixture , you don't have that ?
  5. Jan 5, 2012 at 6:00 PM
    4x4jeep
    Kyle
    Destin FL.
    I will have the site ready but want to just be able to pump out of truck. Thanks
  6. Jan 5, 2012 at 6:01 PM
    4x4jeep
    Kyle
    Destin FL.
    So will be wanting cement ready to pour
  7. Jan 5, 2012 at 6:02 PM
    jflan
    Vancouver, WA
    I think what you want ready-mixed concrete....
    Cement is a component of that.
    I Googled your area and $70 - $100 per CY came back.
    You will have to call around (with your mix design) and get some quotes.
  8. Jan 5, 2012 at 6:03 PM
    4x4jeep
    Kyle
    Destin FL.
    Ok thanks. New to all the lingo haha. Have friends that can help get sit ready. Gonna be putting a floor in my pole barn to build a shop
  9. Jan 5, 2012 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    You gonna finish the slab yourself ?
  10. Jan 5, 2012 at 6:05 PM
    jflan
    Vancouver, WA
    You don't "pump" out of the truck .....hehehe
    You back the truck up to a concrete pump if you have difficult access.
    If you have good access, you can "tailgate" out of the truck and not have to buy pump time.
  11. Jan 5, 2012 at 6:08 PM
    jflan
    Vancouver, WA
    Yes, aggregate :rolleyes:
    Typical is 3/4" rock.....depending on the mix design.....good, round rock where I am.
  12. Jan 5, 2012 at 6:12 PM
    4x4jeep
    Kyle
    Destin FL.
    What about a "black top" asphalt doesn't freeze here and I hear its much cheaper. Anybody know anything about that?
  13. Jan 5, 2012 at 6:12 PM
    OZ-T
    Peter North
    British Columbia
    Navvy jack is aggregate and sand
  14. Jan 5, 2012 at 6:13 PM
    OZ-T
    Peter North
    British Columbia
    Is the building going to sit ON the asphalt or concrete ?
  15. Jan 5, 2012 at 6:17 PM
    jflan
    Vancouver, WA
    Check your overhead clearance and compare to the truck you want to use.
    You might be able to drive inside and tailgate.
    You will need ventilation to evacuate the diesel fumes from the truck. That is if you can get the truck inside.
    Consider renting a couple of 36" fans and pull the truck outside from time to time during the pour if necessary.
    If you can't get the truck inside you will have to pump it. Or wheel it (wheelbarrow) but that would be brutal and labor intensive to get it down fast.
    Guessing at about 900 square feet...
    Prolly need about 3-4 guys that can finish if you want a nice slab. And maybe a couple of squids to help you get it down. That's if you're not wheeling it.
  16. Jan 5, 2012 at 6:18 PM
    jflan
    Vancouver, WA
    Yes, me savvy.
    :p
  17. Jan 5, 2012 at 6:26 PM
    OZ-T
    Peter North
    British Columbia
    I learned something new today , Navvy jack is a BC term , I thought it was a common term .
    In British Columbia, "navvy jack" is a common term in construction and landscaping trades and in their respective supply stores for 1/2", 3/4" crushed rock and sand to be mixed with Portland cement to make concrete.[6] The usage derives from "Navvy Jack", by ordinary name Jack Thomas, a former navvy who used a rowboat to mine good-quality gravel from beaches in West Vancouver and infrequently ran a rowboat-ferry for settlers on Burrard Inlet and English Bay
  18. Jan 5, 2012 at 6:26 PM
    jflan
    Vancouver, WA
    You said this was an existing structure, right ?
    No, do not do "blacktop" for a shop floor....mucho ghetto.
  19. Jan 5, 2012 at 6:26 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    You shouldn't have to pump 11 cubic feet? How thick is your pole barn floor. Find someone that can get you a deal down there for a yard of concrete. There's 27 cubic feet in a yard.
  20. Jan 5, 2012 at 6:27 PM
    Trapper6speed
    Stock
    Ya we don't use that lingo down here. We use inch and a half lime stone.
