Cement Tacos let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRJ1014, Sep 8, 2016.
  1. Mar 1, 2018 at 8:11 PM
    #2281
    hellppy
    hellppy Well-Known Member
    Sean
    Phoenix, AZ
    2018 TRD Off-Road DCLB
    Nice!! Very cool man, I can't wait to see it come together!!
    Code[QUOTED] likes this.
  2. Mar 1, 2018 at 8:37 PM
    #2282
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Indeed, the wait is killer. Ordered mine in November, received it in February. Now I’m waiting for parts.
    I have the following:
    RCI skid plates front to back.
    RCI aluminum bed rack.
    CVT RTT.
    Deaver U402 II’s
    Addictive Desert Designs Honeybadger front bumper.
    Total Chaos Uniball UCA’s
    Total Chaos bed stiffeners.
    Total Chaos King Bump Stop mounting kit.
    Waiting on:
    King OEM Extended Travel shocks w/ 700# coils.
    King rear 2” x 4” bump stops.
    SDHQ Nittro REM polished 4.88 gears (en route).
    ARB front air locker.
    C4 Fabrication Ovelrand HC rear bumper w/ tire swing out.
    Icon Rebound Wheels.
    Tires are undecided, but probably Toyo M/T’s in 285/75/17
    Warn 10,000 lb winch.
    Switch Pro
    TRD Pro grill (any day now).
    I think that’s it. :spending: Thx TW.
    And welcome to TW!
    Bridge4, Intrepid, jhipwundah and 2 others like this.
  3. Mar 1, 2018 at 8:47 PM
    #2283
    zznalg
    zznalg Well-Known Member
    Rocky Mountain Southwest
    2010 Double Cab TRD off-road
    Hey Canook, Where'd you get the Canadian flag? From, a fellow Canadian
  4. Mar 1, 2018 at 8:50 PM
    #2284
    Spackler
    Spackler Well-Known Member
    Looks cold. Spring has sprung down here.
  5. Mar 1, 2018 at 8:58 PM
    #2285
    zznalg
    I just ordered a DCSB OR manual cement and am stoked. My last Tacoma was a 2010. This will be my sixth Toyota truck since 1989! Plan to see it in May.
    Intrepid, MMoreno16 and Code like this.
  6. Mar 1, 2018 at 9:39 PM
    #2286
    Tredd
    Tredd Well-Known Member
    Los Angeles
    2018 Tacoma TRD Sport DCSB
    Just picked her up from getting ceramic coated. Needs the Pro grill ASAP!
    SilverII, sirhc91, BKJ0E and 7 others like this.
  7. Mar 2, 2018 at 6:22 AM
    #2287
    H3llRid3r
    SLcUT
    Ceramic coated?
  8. Mar 2, 2018 at 12:37 PM
    #2288
    XenonDepot
    XenonDepot Well-Known Member Vendor
    Sounds like a pretty good list you've got there. Add me to the list of people eager to see pictures when you're all done!
    ~Robert
  9. Mar 2, 2018 at 1:07 PM
    #2289
    Captspaulding1000
    Captspaulding1000 Well-Known Member
    how did you get the rims black?
  10. Mar 2, 2018 at 1:35 PM
    #2290
    Tredd
    Los Angeles
    I assume you meant black. Plasti-dip!
    Intrepid likes this.
  11. Mar 2, 2018 at 1:35 PM
    #2291
    Ghost09
    Ghost09 Well-Known Member
    I am inlove with the TRD Pro in this color :D
  12. Mar 2, 2018 at 2:07 PM
    #2292
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
    What did you mean by "ceramic coated"?
  13. Mar 2, 2018 at 2:13 PM
    #2293
    Tredd
    Los Angeles
  14. Mar 2, 2018 at 2:30 PM
    #2294
    Jester2552
    Jester2552 Member
    2018 Cement Gray TRD Off-Road
    Found some snow in Alta, Utah a couple weeks ago
    JIMMEISTER, SilverII, BKJ0E and 10 others like this.
  15. Mar 2, 2018 at 9:52 PM
    #2295
    Code
    Code Member
    Fortunately I live in one of the most scenic places in Oregon... pictures will follow.
  16. Mar 3, 2018 at 6:36 AM
    #2296
    Lancelotless
    Lancelotless Well-Known Member
    Louisiana
    2018 Toyota Tacoma TRD Off-Road Cement
    Best pictures yet! :)
    Jester2552[QUOTED] likes this.
  17. Mar 3, 2018 at 8:30 AM
    #2297
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Found some snow or found a Tacoma?
    cemented likes this.
  18. Mar 3, 2018 at 8:32 AM
    #2298
    JMB Glass
    JMB Glass Active Member
    Josh
    Brattleboro, Vermont, USA
    2018 Cement Off-Road DCSB auto with "Pro" mods
    Pro hood/scoop SEMA 4Runner Pro wheels Pro tail lights Non-Lux side emblem "black out" covers Deselen "TRD" emblem Pro skid plate Pro Rigid Industries Fogs with Amber covers OEM Pro front grille Pro TRD shift knob
    I have yet to see in person a 2017 Pro in the Cement color, but it looks from the many photos I've seen that it was a lighter and maybe "flatter" color than the 2018 Cements. I have a 2018 OR in Cement and it seems to be quite a chameleon color depending on the lighting (which is kinda cool), but I can't help but think it's a darker color than the 2017 Pros were. I've seen some photos of the Pro where it does indeed look darker and occasionally my truck looks like that lighter, paler grey. But mostly mine and the other 2018's I've seen look darker, maybe even slightly more metallic than the Pro. So, am I just seeing things that aren't there, and 2018 Cement is exact same as 2017, or am I correct in thinking that Toyota changed the color a bit? Thanks in advance.
  19. Mar 3, 2018 at 8:34 AM
    #2299
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    It wouldn't be the same paint code if Toyota had changed the color even a little bit.
    JMB Glass[QUOTED] likes this.
  20. Mar 3, 2018 at 9:10 AM
    #2300
    hellppy
    Sean
    Phoenix, AZ
    Yep, it's the exact same color. It looks different in all kinds of lighting.
    jhipwundah, Intrepid and treimche like this.
