Cement Tacos let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRJ1014, Sep 8, 2016.
  1. Apr 18, 2022 at 6:30 PM
    Nymbus
    Nymbus Well-Known Member
    2021 TRD Offroad DCSB Cement 4x4 AT
    A little late to post this but this is the first time my taco has ever seen snow when I was in VA. And also some F15s in cement color.
    75229709-F9C5-49AC-A660-1A5780E7EC14.jpg 676AFDAB-76B6-444C-AE7D-D76A7BB1C872.jpg
  2. Apr 18, 2022 at 9:17 PM
    SCUfan117
    SCUfan117 Well-Known Member
    2021 DCSB TRD-OR 4x4 Cement
    Awesome setup! :thumbsup: What size Wildpeaks did you go with? Any issues finding TPMS sensors for the steelies? What paint did you go with?
    I just got a set of 17" FJ steelies and am in the process of doing the same setup. Planning on color matching them Cement and going with 265/70/R17 Falken Wildpeaks.
  3. Apr 19, 2022 at 4:00 PM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    Same size as you. 265/70-17. I did have some rubbing on the mud flaps the the suspension compressed while turning prior to the lift. As for TPMS sensors the stock ones from my alloy wheels worked fine. I think it's only the steel rims on the down level trims that need a special sensor. I also got the factory center caps. Those are damn pricy but look so good in my opinion.
    Paint is PPG PSX-700 epoxy in RAL 7037 It's originally designed to offshore oil rigs and is super durable.
    More info here: https://www.tacomaworld.com/threads/show-off-your-steel-wheels.467479/page-40#post-26218441
  4. Apr 19, 2022 at 6:43 PM
    SCUfan117
    Ah ok. I'm on stock TRD-OR suspension with a set of Tufskinz mudflaps, hopefully they don't rub or are trimmable if they do. I wonder if the TPMS sensor is the same between the TRD-OR 16" alloys and the TRD-Sport 17" alloys -- as in if my TPMS sensors will transfer over to the steelies like yours did. I'll probably end up going with the OEM center caps, I think I saw ~$43 each from my local dealer. Thanks for the paint recommendation and your original thread!
    Did you go with any particular set of black lug nuts? Am I missing any other things that I'll need? Haha, thanks!
  5. Apr 19, 2022 at 7:59 PM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Cement for the win!
    Mrod18, skidooman, Auzea and 10 others like this.
  6. Apr 20, 2022 at 6:03 AM
    Tacomanchild
    Tacomanchild asphinctersayswhat
    Tire/lift specs?
    Thomasf94 likes this.
  7. Apr 25, 2022 at 6:51 PM
    iNfectious
    iNfectious Well-Known Member
    Q
    Lone Star State
    '18 TRD Sport 4X4 DCSB
    New look with some FN wheels!
    markram, Camerasandcoffee and Jyruiz like this.
  8. Apr 26, 2022 at 12:46 AM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    those look good. I really like cement with bronze wheels
    iNfectious[QUOTED] likes this.
  9. Apr 27, 2022 at 9:00 AM
    Tacomags
    Tacomags Well-Known Member
    Austin, Texas
    2021 TRD OR DCSB 4x4
    17" 4Runner wheels, 32" Nittos, Dobinsons IMS, RRW sliders, Total Chaos bed stiffeners, custom seat delete, Decked, Super Pacific X1
    Could you talk more about your IMS setup front and rear? Looking to also go this route but will be going with heavy duty springs for a camper I'm getting installed.
  10. Apr 29, 2022 at 7:07 AM
    Omegastu
    Omegastu Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
    These look great. What size tires and do you have a lift? Looks like it.
  11. Apr 29, 2022 at 7:55 AM
    Tacomatrd420
    Tacomatrd420 Well-Known Member
    2018 tacoma trd sport double cab 6 spd
    Ome heavy duty rear leaf springs. El112r. Canopy is semi camperized, pull out tool storage , solar power with rear agm deep cycle battery. Light bars. Front rear sides. Roof basket.
  12. Apr 29, 2022 at 10:01 AM
    Swampdog2019
    Swampdog2019 Active Member
    North Fla
    2019 TRD OR 4X4 DC
  13. Apr 29, 2022 at 5:20 PM
    SoggyTacox
    SoggyTacox New Member
    2020 cement gray tacoma
    Eibachs
    Mrod18, gnu60, siundon and 3 others like this.
  14. Apr 29, 2022 at 6:20 PM
    Ghost09
    Ghost09 Well-Known Member
    Is that the XP Predator package? Love those wheels! wheel+tire specs please!
  15. Apr 30, 2022 at 4:25 AM
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    Sure! I'm running the 352 coils up front and the 110 leaves in back. I went with the longer coils in anticipation of adding a bumper and possibly a winch and the lighter leaves as I run empty most of the time and even loaded up for camping I'm less that 500lbs.
    Currently its at 2.5" up front and 2" in back. Once the bumper is on I should have 2" of lift front and rear. As for the ride, I really like the IMS valving.
    It rides a bit stiff like the stock sport suspension which I really liked and does an excellent job of smoothing out bigger hits. I did realize after I installed the suspension that I really needed UCA's to get the caster angle back to where I liked it. When I had the initial alignment done while it was "in spec" it followed the road camber and was a bit nervous at 80mph. Getting the caster angle into the 3+ degree range helped significantly.
    Lots of good info in this thread if you haven't already seen it:
    https://www.tacomaworld.com/threads/dobinsons-16-taco-suspension.474308/#post-14348918
    9mmMike and Tacomags[QUOTED] like this.
  16. Apr 30, 2022 at 1:41 PM
    Rmac7131
    Rmac7131 Member
    Out at city of rocks, Idaho
    markram, Cutty95, geo8866 and 7 others like this.
  17. May 2, 2022 at 6:41 PM
    horner21
    horner21 Well-Known Member
    Guthrie
    Looks good anymore pics? Thinking about getting ARB! What’s your suspension and tire setup?
    Swampdog2019[QUOTED] likes this.
  18. May 2, 2022 at 6:57 PM
    iNfectious
    Q
    Lone Star State
    Thanks! 265/70-17 with Bilstein 6112/5160 and RXT leaf pack
  19. May 3, 2022 at 5:33 AM
    Swampdog2019
    North Fla
    2019 TRD OR 4X4 DC
    Stock suspension at this time, 3" lift done by dealership, tires are Hankook Dynapro AT2 275/70R17
  20. May 3, 2022 at 7:27 AM
    bbartol
    bbartol Well-Known Member
    Brandon
    Central Ohio
    2025 TRD Off-Road Premium in Terra
    Now waiting on my recent order for the puddle pods and considering ordering the OEM black bezel/framed tail lights from the 2020/2021 models.
