Cement Tacos let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRJ1014, Sep 8, 2016.
  1. Dec 15, 2017 at 10:41 AM
    #1521
    OCPaisa
    OCPaisa Well-Known Member
    Peter
    O.C.
    2004 Toyota Tacoma 4x4, MT
    OE 17" 4runner TRD Pro wheels. 265/70/17 BFGoodrich KO2
    I guess I'll survive with my stock grille for now till there's more concrete info. The fact my current grille is now black helps the pain lol.
  2. Dec 15, 2017 at 10:48 AM
    #1522
    ken360
    ken360 Well-Known Member
    Nebraska
    2018 Tacoma TRDOR DCSB Cement
    I did the swap to a 2017 pro grill added the plexiglass and have noticed no difference with my TSS
    OCPaisa likes this.
  3. Dec 15, 2017 at 10:51 AM
    #1523
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    you added your own plexi glass? or an insert from Toyota?
    can you post a pic?
  4. Dec 15, 2017 at 10:55 AM
    #1524
    kurpak
    kurpak Well-Known Member
    2018 Off Road
    I read through the tss radar recalibration instructions pdf, it looks like when the sensor is calibrated it goes through a learning cycle to set it's alignment in a parallel axis to the flat ground surface. There are 3 types of radar installation points, sr5 (A) sport and off road grilles (B) and pro grilles (C) Moving a sensor that has been calibrated at version A or B to the version C location (just moving the sensor down a few inches) probably has no ill effect, as what the alignment most cares about is 0 rotation on the up\down in relation to the flat ground.
    It certainly wouldn't hurt to recalibrate the sensor, but the pro grille was designed with this system and allows a consistent attachment point in relation to the other grilles and the truck's level. I'm going to be trying this myself here in a few weeks to see how well it works.
    Now if you went with an aftermarket grille and attached the sensor to a point that wasn't centered or perfectly level to the ground like the oem grilles, or you had an obscene lift in the front or rear only (tilting the truck's front\back end up or down out of the factory ratios) then you most definitely would want to run the calibration.
    It is possible that there is a height ratio between the camera and calibrated radar sensor height as they work in tandem, but we won't know until either Toyota releases some tech docs on how this system actually works, or people just try this and report it works fine in the real world. The pre-collision will turn itself off if it senses something is wrong with the system, so if you try this and don't get any lights or menu warnings there's a good chance it's working fine and is happy, we'll see.
    arnette64 and OCPaisa like this.
  5. Dec 15, 2017 at 10:56 AM
    #1525
    Bretsuaz48
    Bret
    Surprise, Arizona
    2016 Sport
    The dealership said the part number was the same from the 2017-2018. But now I am thinking that is wrong. The grill on that pro is definitely different. The dealership is being really cool about it. I think they are still learning about the 18s and TSS stuff as well.
  6. Dec 15, 2017 at 11:00 AM
    #1526
    Bretsuaz48
    Bret
    Surprise, Arizona
    2016 Sport
    I did get an intermittent warning light. They adjusted it. I think the warning may be intermittent still. I am thinking that this is not the correct grill for this truck, even though some Toyota information indicated it will work on the 18. I thought it was weird that the grill they removed had unobstructed glass looking Toyota emblem, while the pro had no such protection.
  7. Dec 15, 2017 at 11:22 AM
    #1527
    OCPaisa
    Peter
    O.C.
    It's time....
  8. Dec 15, 2017 at 11:55 AM
    #1528
    Bretsuaz48
    Bret
    Surprise, Arizona
    2016 Sport
    I am in contact with the dealership. Trying to figure it out.
  9. Dec 15, 2017 at 12:02 PM
    #1529
    ken360
    Nebraska
    Yes I added my own plexiglass and it honestly works great it looks way better than OEM the only downfall would be having to take it apart if it got really dirty but take it apart would only take about 20 minutes I was going to do a Tutorial but I got too excited about the grill and just put it on . I’m traveling right now but once I get back to my truck I’ll get some pictures for you guys and and explain how the process works .
    OCPaisa likes this.
  10. Dec 15, 2017 at 12:12 PM
    #1530
    ibensted
    ibensted Active Member
    Ian
    North Vancouver
    2018 TRD Pro
    Black wrap roof
    Thanks Ken, look forward to it. From what I can tell the 2017 grill already had the mount for the sensor and on previous models it just sat there empty. I have just placed my deposit on my 2018 cement OR. Hoping to swap the grill as soon as it arrives. Also considering getting the OR wheels painted or powdercoated (perhaps the the silver machined portions).
    ken360 likes this.
  11. Dec 15, 2017 at 12:45 PM
    #1531
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Yes, I'm anxious for a report as well b/c the dealership isn't helping, or even willing to help. All they would say is that Toyota is telling them not to alter the trucks b/c it will affect how all the TSS-P works. I have a deposit down on an '18 Cement as well. Should be in end of the month or possibly mid January. I want to put the Pro grill on and an aftermarket bumper.
    When is someone going to start an '18 build thread?
  12. Dec 15, 2017 at 12:54 PM
    #1532
    OCPaisa
    Peter
    O.C.
    Soon as you send me the parts brother!
    orangeracer likes this.
  13. Dec 15, 2017 at 12:58 PM
    #1533
    H3llRid3r
    SLcUT
    I think we had this discussion once before - LOL!
  14. Dec 15, 2017 at 1:08 PM
    #1534
    OCPaisa
    Peter
    O.C.
  15. Dec 15, 2017 at 1:15 PM
    #1535
    ken360
    Nebraska
    I will be starting a build thread in the next week or so
  16. Dec 15, 2017 at 1:46 PM
    #1536
    H3llRid3r
    SLcUT
    Perfect! What are you planning?
  17. Dec 15, 2017 at 3:22 PM
    #1537
    ken360
    Nebraska
    Well I already have a lot of stuff from my last truck (2016 taco) that was totaled recently. But it’s an overland style build which fits my needs perfectly. The canopy is coming in about 2 weeks.
  18. Dec 15, 2017 at 4:43 PM
    #1538
    H3llRid3r
    SLcUT
    Nice. That should make it lighter on the pocket book. Any plans to install a Fab Fours front bumper? :D
  19. Dec 15, 2017 at 6:17 PM
    #1539
    ken360
    Nebraska
    I need to do a full suspension make over to account for the weight I’ve got on it already. Full skids, slider, full front runner roof racks. But someday rear swing out high cleanrance bumper. And probably a slimline front bumper
  20. Dec 16, 2017 at 5:24 AM
    #1540
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    So plans changed, Going to have to cancel my order. Found a DCSB 18' TRD OR 4x4 w/tech in cement and with a manual transmission in stock at a dealer up north! Went for a scenic drive yesterday, 5hrs but totally worth it. Going it for even cheaper then the one I ordered. Paid invoice -$750 college rebate, so I was happy! Glad to be part of the cement family now :)
    FlipDiver likes this.
