center air vents not blowing out ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slick8810, Jul 13, 2009.
  1. Jul 13, 2009 at 6:53 PM
    Slick8810
    Slick8810 [OP] Well-Known Member
    Panama City, FL
    01 Tacoma Prerunner SR5
    3" lift, 20% tint, billet grille
    my side vents by the windows are blowing out really good but the two above the cd player are barely blowing out. what can cause that? Has this happened to anyone on there first gen tacoma?
    Black97v6MT likes this.
  2. Jul 15, 2009 at 3:44 PM
    trix_17
    trix_17 New Member
    mine do that too. I don't know why.
    Anyone know?
  3. Jul 15, 2009 at 6:59 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I noticed that my center vents don't blow very much while the fan selector is set to floor AND dash. If I set it on dash only all vents work fine. Also, the plumbing under the driver's side dash had come apart. I have plans to fix it better and insulate it better but have to many irons in the fire right now (facing a move to DC).
    Try switching to dash only, see if that makes a difference.
    Derek P
  4. Jul 15, 2009 at 7:00 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    duct work behind the dash might be bad. just an idea though
  5. Jul 25, 2009 at 7:15 PM
    lsntennis
    lsntennis New Member
    Missouri
    97 Tacoma SR5 Extended
    I had the same problem, air wouldn't come out of the left center vent. I simply took off the slider knobs by pulling on them for the temp controls and popped out the panel with a flat-head. There are two screw which hold the center cluster panel trim in. One on is the right side of the unit, the other is angled and in the top left corner. Once I took these two screws off, i used my flat-head to remove the trim. With the trim off you can pull out the air vents, which also exposes the in-dash cd player if you want to replace it with an aftermarket one. The diffuser was simply off the track and pointing to the right so if sent all the air in through the center right vent. I aligned the diffuser and re-inserted the vents. Snap the trim back on, insert the screws, put the temp panel back on, and finally re-install the control slider knobs. It took me only 5 or 10 minutes to do.
  6. May 30, 2011 at 9:13 PM
    abbywig
    abbywig Member
    Bill
    Beaverton,Oregon
    1997 Toyota Tacoma
    I've read a number of different ideas and here's what I did and I had the vents out in 2-3 minutes. Used some needle nose pliers and pulled on the vent while I used a slot screw driver and inserted it in the side of the vent and pried out while pulling with the needle nose pliers. Voila, it popped out !!!!!!!!!!!!!
    Good luck
    Bill
  7. Mar 10, 2017 at 12:59 PM
    Bobby_B
    Bobby_B New Member
    2004 Toyota Tacoma Prerunner
    Bug shield, somewhat worthless Nerf bars, rigged gas pedal, Jimmy rigged battery receptacle, and a Gaylord tonneau cover.
    I have the same issue. IsnTennis posted a good reply, but I think my issue may be deeper. The only vents that blow on any setting is the bottom vents and then 6th e side vents a bit. I get nothing out of my middle vents and defroster. The defroster is my biggest concern since I'm moving to the South and I'll definitely need that in working order. Any others have this issue? I'm not sure if it's a 1st gen issue or if something busted back there.
  8. Dec 5, 2020 at 3:25 PM
    Natopotatox
    Natopotatox New Member
    Nate
    2003 Black Tacoma Prerunner Xtracab V6
    Led headlights + Taillights Smokey headlights and taillights Blacked out bumper
    Anyone ever figure this out why?
  9. Nov 7, 2024 at 6:52 PM
    Lathon Daniel
    Lathon Daniel New Member
    Lathon
    1996 2.7l manual 4x4 tacoma
    I was just working on my 1996 tacoma because the vent selector is jammed up and I read abt a guy that dropped something in there that stopped it from working so I thought i’d take mine apart and see what I could find.
    I’m still working on that part but I did find this metal plate that blocks the center two vents. It doesn’t move no matter what mode I put it in and it almost completely blocks airflow from the center vents I think it’s part of the selector but it appears to be broken in my tacoma. Idk, maybe it’s a common failure point in the 1st gen’s.IMG_2997.jpg
  10. Nov 8, 2024 at 5:33 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    i have noticed on my '97 rig that the center vents above the pull-out cup holder are a bit different on each side
    ...not sure when exactly this started to become noticeable
    but the airflow from the left center vent is Much More then what comes out of the right vent in the center
    it is quite an oddity!? like there is some restriction on that right side center vent but i have no clue what it looks like behind there
    could it be that metal flap in your picture or what do you think is going on :notsure:
    is the duct work in your rig covered in that dirty film like in your pic?
