Center bearing and U joints
Discussion in 'Technical Chat' started by devil1, Feb 9, 2015.
  1. Nov 6, 2015 at 2:28 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    might be reviving an old thread but this helped a lot! thanks
    just gonna have to find a center bearing though...out of stock on Amazon
    looks like its on rockauto though for 50$
  2. Nov 6, 2015 at 2:35 PM
    99TacoDriver
    South Louisiana
  3. Feb 27, 2017 at 11:32 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Is this RWD or 4WD bearing? Saw a review for it on Amazon said it didn't fit 4WD. Whats the difference? Anyone know dimensions of 1st gen compared to 2nd gen Spicer center bearings?
  4. Mar 6, 2017 at 4:32 PM
    CO_0321er
    CO_0321er Well-Known Member
    Does anyone know if these are for the RWD or 4WD? or do both the U joint kit and Carrier bearing listed here work for any model 05-15 both RWD and 4WD?
  5. Jun 9, 2017 at 12:37 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
  6. Jun 11, 2017 at 6:07 PM
    SOMDTACO
    Sean
    Southern Maryland
    Hmm doesn't sound promising then.
  7. Aug 10, 2017 at 8:15 PM
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
  8. Mar 22, 2018 at 8:53 PM
    Runnertaco
    Runnertaco New Member
    2000 Tacoma SR5 V6 Extended Cab
    Homemade (heavy) front bumper, currently on new Wheeler 3inch springs (yielded ~2.5inches over stock springs with tacoma 5100s topped out) on Tundra 5100s, and an add-a-leaf in rear, new 5125 rear
    Just installed the Spicer listed above for the 1st gens. Installed on a 2000 4X4 SR5 V6 extended cab. Side by side they are an identical part. Has toyota on the rubber and another part number that from my research shows that it fits the Hilux of the same year. 75 from Amazon. Hopefully it will last longer than the last one from NAPA that made it maybe 20,000 miles and about 4 to 5 years ish. Rubber was shot and loosing grease. Original lasted 230k ish. I will try to remember to update as time goes on. Putting it to the test in the next few days with a 1,000 mile minimum road trip. I also added spacers to try to help with the angles. Ended up with 1/4inch plate to get the angles close.
    Biscuits likes this.
  9. Mar 27, 2018 at 9:11 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Which Spicer u joints are needed? Ive heard some not great stuff about Moog quality. How many Spicer ujoints are needed ? 2nd gen 4x4 or 2011
  10. Mar 27, 2018 at 10:16 AM
    StrangeDuck
    San Diego
    I believe you need three 1330's for the rear shaft and two 1310's for the front. You can choose if you want joints with zerks or not. Whichever way you go make sure you get joints with outside snap rings.
    REDdawn6[QUOTED] likes this.
  11. Mar 27, 2018 at 10:20 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  12. Mar 27, 2018 at 10:42 AM
    StrangeDuck
    San Diego
    Taco 422 and REDdawn6 like this.
  13. Jul 10, 2018 at 11:35 AM
    beavis87
    El Paso
    '10 Silver TRD OR
  14. Jul 10, 2018 at 3:27 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Just somethings to note.
    Spicer 5-213X:
    • double seals
    • zerk fitting on the body
    Spicer 5-1330-1X:
    • triple seals
    • zerk fitting on the cap
    • beefier and a better choice for severe use such as offroad
  15. Dec 14, 2018 at 1:47 PM
    #35
    beavis87
    El Paso
    '10 Silver TRD OR
    From another thread:
  16. Nov 16, 2020 at 8:36 AM
    #36
    E.RDZ_TACOMA
    E.RDZ_TACOMA Well-Known Member
    Denton, TX
    2007 Blue Tacoma Access Cab 4×4
  17. Nov 16, 2020 at 8:06 PM
    #37
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    Carrier is Spicer 5002334. All three u-joints on the drive shaft are Spicer 5-1330-1x. I used these part numbers for mine a couple years ago.
    Good luck!
    E.RDZ_TACOMA[QUOTED] likes this.
  18. Nov 16, 2020 at 9:13 PM
    #38
    E.RDZ_TACOMA
    Denton, TX
    Canoehead[QUOTED] likes this.
