center carrier bearing replacements help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Smok3o3, May 7, 2011.
  1. May 7, 2011 at 12:51 AM
    Smok3o3
    Smok3o3 [OP] Member
    Colorado
    4x4
    Hey everyone, I have a center carrier bearing that needs replace, I was wondering can I just buy the center of it somewhere and switch it out instead of buying the whole support?
  2. May 7, 2011 at 1:01 AM
    EddieC
    EddieC Well-Known Member
    Eddie
    K-town Hollywood CA
    02 2.7 4cyl reg cab
    magnaflow exhaust
    how can you tell the carrier bearing needs replacement? My truck makes a weird squeel now and then and someone told me thats what it could be. I've taken it to 3 mechanics with no luck...
  3. May 7, 2011 at 1:11 AM
    Smok3o3
    Smok3o3 [OP] Member
    Colorado
    4x4
    Its the way it sounds while driving it my whole truck raddled, recently I took my whole driveshaft off with the carrier bearing and use only front wheel drive and my truck rides fine. The whole piece cost around a hundred so I want to know if anyone knows if anyone sells just the bearing so I can just switch that out and save some money.
  4. May 7, 2011 at 1:19 AM
    Smok3o3
    Smok3o3 [OP] Member
    Colorado
    4x4
    also what do you look for for a good center bearing?
  5. May 7, 2011 at 1:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    OEM Toyota Center (carrier) bearing... $200
    this is the part,no replacable center
  6. Jun 9, 2011 at 7:33 AM
    mihiinme
    mihiinme New Member
    Maine
    06 Double Cab SR5 Tacoma
    Should there be any play in that center bearing? I have the u-joint right behind it thats bad. Wondering if I should replace both?
  7. Jun 9, 2011 at 7:38 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
  8. Jun 9, 2011 at 8:19 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Holy Shit that a ridiculous price! I think I only paid $20 for the one on my s10 and it looks basically the same just different mounting points.
  9. Jul 20, 2011 at 3:27 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Thanks for the link Mike!
  10. Jul 20, 2011 at 3:53 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    That would def. resolve any bearing strength & longevity issue unless it vibrates so much thru the elimination of that cheezy rubber grommet (suppressor) that it too would eventually prematurely wear out, love the concept though..;)
  11. Jul 20, 2011 at 4:05 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    My 71 pickup had a 2 piece driveshaft with the center bearing and in the 27 years I owned it I never changed a thing even beating the hell out of the drivetrain with the 454 in it didn't bother it. That truck is gone now, but I have a spare driveshaft in my garage that I may have to see if the local machine shop can cut and balance for me. It would eliminate the cardomon joint and move the slip joint farther up towards the center bearing but it just might be a bit better than the stock Toyota shaft and it doesn't look any bigger. Any GM 3/4 ton truck up to 1987 had a similar setup. I do like the solution at ttora though.
