center consol mod/ other easy mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by txfisherman76, Apr 8, 2012.
  1. Apr 8, 2012 at 1:33 PM
    txfisherman76
    txfisherman76 [OP] Member
    Bret
    Pearland
    09 TRD sport DCLB
    bilstein 5100s set at 2.5, in channel vent visors, and black weathertechs
    Well I ordered my Bilstein 5100s and I needed to keep my self busy so I dont go crazy while im waiting, i also figured i look at other peoples set up enough so i guess its my turn to share. i rigged up the center consol with the factory net to hold my sunglasses cleaner, also mounted my little surefire using a bycicle pump mount (saw it on tacoma world a while ago). took a black basket from walmart and cut it to replace the net. i think it is better because i can now clip my knife on there and its sturdier. mounted my streamlight in between the drive side door and seat, it is mounted so i can charge it down there too. Also found some tool boxes at sears which fit perfectly in the back cubby holes. let me know what yall think about it, all in all the center consol cost about 20 bucks and the tool boxes are 8 bucks a piece so its a cheap and pretty easy mod.
  2. Apr 8, 2012 at 1:36 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    i like those tool boxes.
  3. Apr 8, 2012 at 1:48 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  4. Apr 8, 2012 at 3:48 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    x2
  5. Apr 8, 2012 at 5:28 PM
    txfisherman76
    Bret
    Pearland
    09 TRD sport DCLB
    Thanks guys and yeah the tool boxes are really good big enough to hold most of my tools that I need
  6. Apr 8, 2012 at 10:32 PM
    Cortland
    Cortland
    Arizona
    can you post a link for the exact toolboxes you used please?
  7. Apr 8, 2012 at 10:49 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    sub'd
  8. Apr 8, 2012 at 10:50 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    thats one expensive flashlight you have there, yet one that will never fail you :D where do you run the wires to recharge it?
  9. Apr 8, 2012 at 10:51 PM
    Frostbyte
    Northern Utah
    this too
  10. Apr 9, 2012 at 8:09 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Those tool boxes do fit nice in the cubbys if you want to keep the cubbys in there. I just took all that cubby stuff out of the truck and now have a lot more room for things.
  11. Apr 9, 2012 at 9:46 AM
    txfisherman76
    Bret
    Pearland
    09 TRD sport DCLB
    yes it is but it is def worth the money. and what i did was just run the wire along the trim and up to a cig lighter adapter, and i ran the adapter to the battery so everything i plug in stays on when the truck is off. the cig adapter is mounted in that trim next to the parking brake. im attacting pictures so you can see where i put the plug and get kind of an idea of how i did it. right now i got my flashlight, GPS, and radar detector ran on that adapter.
    I have thought about taking out the cubbys but I keep talking my self in and out of it lol
    heres the link to the tool boxes:
    http://www.sears.com/shc/s/p_10153_12605_00965117000P?prdNo=14&blockNo=39&blockType=G39
