Center Console Back Removal
Discussion in 'Lighting' started by TRD Larry, Feb 23, 2012.
  1. Feb 23, 2012 at 6:36 PM
    TRD Larry
    TRD Larry [OP] trd larry
    Larry
    South Park, PA
    08 Tacoma Black,Sport package,
    Sport pedals, Extang full-tilt cover, Magnaflow exhaust system, XPEL invisible paint protection, TRD short Shifter, Hood struts, Homelink mirror, Dbl power outlets,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Muth heated signal mirrors TSB. Lo-Tek Pilllar pod with Glow-Shift gauges, 4x4 illuminated switch, Pioneer Z110BT (upgraded to Z130BT) w/2011 toyota tailgate backup camera,traffic tuner, parking brake bypass. Leather interior w/heated seats. LED's installed in glove box, center console, front and rear cupholders, rear console vent, AFE CAI, LED taillights, under hood lights, LED bed lights, oil catch can, extra D-rings installed in bed, frame replaced, Bilstein 5100, fronts set at.85, FOCAL Auditor 6.5" componet speakers. Replaced lower center dash panel with 2011 dash panel, installed USB charger and relocated seat heater switches to lower panel, FLYZEYE lights, APEX stealth LED light bar brackets and Cali Raised LED light bar, Illuminated Ignition Ring,Diff. Breather mod, AC mod.
    Has anyone removed the back from the front center console. I have searched and can't find pictures or removal descriptions. I figure the back is held on by clips, but before I start prying and pulling I would ask first. If someone can point me in the right direction i would appreciate it.
    I want to put a led in the back cup holder and a accent led in the vent at the bottom of the console back.
  2. Feb 24, 2012 at 5:05 AM
    TRD Larry
    Larry
    South Park, PA
    Thanks for the info. I was able to pull out the center console. What I'm trying to do now is remove the back panel from the console if it even comes off. I want to put a led in the rear cup holder.
  3. Sep 13, 2012 at 1:10 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    it does come off, just pull gently after seperating the bottom tabs
  4. Sep 13, 2012 at 1:11 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Lol... If you remove the center console the back panel just pulls right off
