center console connector (unused) ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GoBlueFan, Jun 14, 2009.
  1. Jun 14, 2009 at 1:57 PM
    GoBlueFan
    GoBlueFan [OP] Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    I have my center console out and there is a connector (8 or 10 pin) that is not connected to anything. What does it provide? I have my battery disconnected at the moment, so I can't probe it for power. I'd like to tap in and use it if it has power to hardwire my xm unit.
    I know it's an option that I don't have...just curious what it does go to?:confused:
    08 Regular cab with buckets (manual)
    TIA
  2. Jun 14, 2009 at 2:05 PM
    AR_Taco
    AR_Taco Well-Known Member
    Jacksonville Ar
    07 DC 4x4
    3" lift, Flowmaster exhaust, K&N filter, URD short throw shifter, ScangaugeII
    Would you be talking about this one:
  3. Jun 14, 2009 at 2:09 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    yep, that'd be the critter. What does it go to and does it have a switched 12v wire in it?
  4. Jun 14, 2009 at 2:19 PM
    AR_Taco
    Jacksonville Ar
    07 DC 4x4
    Its the rear locker harness. It's there on all 05+ tacomas, I believe.
  5. Jun 14, 2009 at 2:20 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd bet it goes to the inverter that powers the bed outlet. You guys won't have them if you don't have a TRD package.
  6. Jun 14, 2009 at 2:27 PM
    AR_Taco
    Jacksonville Ar
    07 DC 4x4
    I asked a mechanic at the local stealership. But they have been wrong before. But there are the black things just to the left of the steering wheel, same place as your Clutch Start Cancel button, should be six of them, the harness should lead up to one of the unused plugs there.
  7. Jun 14, 2009 at 2:58 PM
    johnecon2001
    Phoenix, AZ
    ^ if it leads to the unused plugs it could be either the diff lock or the inverter. My guess is still on the inverter though. I'll see if I can find pictures of a sport or Off road with the console taken apart.
    http://www.toyotanation.com/forum/showthread.php?t=284662
    Does the connector look like any of those?
  8. Jun 14, 2009 at 3:16 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Picture of it in the second post. Looks to be similar. Bottom line, is that it is just a dead harness correct?
  9. Jun 14, 2009 at 4:52 PM
    johnecon2001
    Phoenix, AZ
    Well yeah, if you have the SR5 without the bed outlet, there's no inverter under the center console (you'd know if it was there).
    I'm 80% sure that's what it is based on the pictures.
  10. Jun 14, 2009 at 5:24 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    for sure there is no inverter. It was just an unused plug. I was hoping it had power (switched). Got to find another source then.
  11. Jun 14, 2009 at 7:19 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    if it runs up to the unused plugs to the left of your steering wheel, maybe use it to bring power down from under your dash somewhere? If you needed a source under the center console.
