Center console fans
Discussion in '1st Gen. Tacomas (1995-2004)' started by (okay), Oct 29, 2023.
  1. Oct 29, 2023 at 10:00 AM
    (okay)
    (okay) [OP] New Member
    2003 Tacoma SR5 4x4
    Does anyone happen to know what is causing the center console fans to stop blowing air? The driver and passenger fans still work just fine but I can't get air from the center. Hoping for a little more warm air heading into the cold weather. All my searches for a part number have been coming up empty.
  2. Oct 29, 2023 at 10:04 AM
    SpokeWench
    SpokeWench Well-Known Member
    Paula
    1998 Tacoma SR5 4x4, Super Pacific X1
    Mystic Purple Mica, Super Pacific X1 (bld 359)
    There is only one, single blower motor. From the picture, you have the setting on defrost, which directs air only to the dash. If it is on the next option over, air is directed to the dash and floor outlets.
    For air out the center ducts, the switch needs to be set to the option with one of the two left-most options.
    Hamer95USA and omegaman1955 like this.
  3. Oct 29, 2023 at 10:07 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    The dial selector on the right is what will change where the air comes from, as said above it's currently on defrost.
  4. Oct 29, 2023 at 10:08 AM
    (okay)
    2003 Tacoma SR5 4x4
    Yeah I get that. The settings are just what I had them on most recently. Regardless of what setting I have fan on, I'm not getting air from the center.
    SpokeWench[QUOTED] likes this.
  5. Oct 29, 2023 at 10:09 AM
    omegaman1955
    omegaman1955 Well-Known Member
    Henry
    Somewhere near Pie Town/Quemado,NM
    '98 Tacoma 4x4 SR5
    Rodents.
    There is only one fan that I know of. The middle vents are blocked.
    I have to take mine all apart to suck the mothers out. Have the fan screened and they still get by.
    A flaw in Tacoma design, most vehicles these days. Intakes are in bad spots and open to critters getting in.
    Hamer95USA likes this.
  6. Oct 29, 2023 at 10:10 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Just wanted to make sure, I would pop out that bezel and see what's going on back there. It's pretty easy to remove.
  7. Oct 29, 2023 at 10:15 AM
    (okay)
    2003 Tacoma SR5 4x4
    I suppose the pic is misleading. I'll take the bezel out and see what's going on. Thanks
  8. Oct 29, 2023 at 10:16 AM
    (okay)
    2003 Tacoma SR5 4x4
    Thanks for the tip. I'll do some more digging in there. Thanks
    Bivouac likes this.
  9. Oct 29, 2023 at 10:19 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Either the Duct work fell off or was not reinstalled correct .
    A nest of some sort is blocking the duct.
    omegaman1955 likes this.
  10. Oct 29, 2023 at 10:23 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When you rotate the 3rd knob (rightmost), can you hear the vent door move behind the dash? I can't remember if it is vacuum actuated or electric motor actuation but do it with the engine running in case it is vacuum.
    The vent door changes position to direct the air from the fan motor to the various vents. As mentioned, the center 2 vents only get air from the fan when that knob is rotated to the 2 leftmost positions on the dial.
  11. Oct 29, 2023 at 10:41 AM
    omegaman1955
    Henry
    '98 Tacoma 4x4 SR5
    Good YT video of how to...and hope plastic doesn't break deal. Take the vent covers off and suck...
    Mine is manual lever to switch to re-circulate.
  12. Oct 29, 2023 at 12:14 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    The air coming from the side vents is when the truck is stationary, yes? They're fresh air vents, of course, so when moving there will be air coming in even if the blower motor is not running.
    Did you confirm the blower motor is operating?
