Center console lid – Stiffer spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evanimpreza, Mar 2, 2018.
  1. Mar 2, 2018 at 3:35 PM
    evanimpreza
    evanimpreza [OP] Well-Known Member
    Evan
    Joplin, MO
    White 2012 TRD Offroad DCSB
    Icon Stage 6, SCS Ray 10s, 33s, Rigid Lighting
    Now that I have added an organizer mesh to the underside of the lid on my center console, it no longer wants to stay up when I open it. Has anyone added a stiffer spring to the hinge area to solve this?
  2. Mar 3, 2018 at 8:46 AM
    evanimpreza
    Evan
    Joplin, MO
    No one else has this same problem?
  3. Mar 4, 2018 at 12:10 AM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I did the same...and my lid does the same... I havent yet tried a stiffer spring. Im not sure where youd get something like that since its not a run of mill kind of spring. Its looks like a circle with two arms correct?
  4. Mar 4, 2018 at 12:25 AM
    evanimpreza
    Evan
    Joplin, MO
    Yes it is. I messed with it a bit today and may have found a good solution. I took off the inner cover of the lid to reveal the spring by unscrewing the 5 little Phillips heads screws. I then grabbed one of the little arms of the spring and pulled it closed, while I shoved a small piece of metal behind it. In my case, I cut a penny in half and stuck it behind the top arm. This effectively increases the spring rate and seems to hold the lid fairly well now. I'm thinking the spring may stretch back out over time, but we'll see.
  5. Mar 4, 2018 at 12:30 AM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Good idea using a spacer. I automatically thought replacement but its much easier to come up with a way to increase the rate of the existing spring rather than a new heavier one.
    dewayne likes this.
  6. Mar 4, 2018 at 7:35 AM
    evanimpreza
    Evan
    Joplin, MO
    Yeah I was thinking about replacement also but I couldn't seem to knock the pin out of the hinge to get the spring off. So I figured this was worth a shot, and it seems to have worked nicely.
  7. Mar 4, 2018 at 9:20 AM
    dewayne
    dewayne Simply Southern.
    Dwayne
    Shenadoah Valley,Virginia
    2015 tacoma AC mettalic grey
    265/75r16 KO2 5100 level at1,75,Icon 3 leaf addaleaf pac,amp,speakers,holster,black out badges
    its called a torsion spring. pretty common. shouldnt be too hard to find. but the spacer idea seems easier
