Center Console Mod - Pic Heavy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Munnyshot, Sep 27, 2017.
  1. Sep 27, 2017 at 12:20 PM
    Munnyshot
    Munnyshot [OP] Active Member
    Lakewood, CA
    2018 SR5 DCSB 2wd
    So I was browsing this forum and came across the thread for the center console organization mod that a lot of people have done. It is a pretty easy mod and is a great way to organize your console.
    Here are the parts that I got from Amazon.com:
    Grid-It organizer:
    https://www.amazon.com/gp/product/B0030BERUK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Vehicle OCD console organizer:
    https://www.amazon.com/gp/product/B00A5UEOLG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    and then some 3M double sided tape from Home Depot. Other people used Velcro, but I dont really plan on removing this organizer any time soon, so the permanence of double sided tape was fine for me.
    So you do have to shave a lot of the edges on the Grid-It to make it fit. Here are some pics of my process:
    1. I cut the edge with a razor blade to expose the plastic frame on both sides where I grinded down the edge.
    2. Then I used a Dremel tool to grind down the black plastic frame all the way down until you start to see the stitching that is holding the elastic pieces and the outer edge in place. **be careful not to grind too far because if these stitches come loose, the straps will come apart. When you finish grinding, you can trim up the frayed edges and use a lighter to singe them shut so they do not fray anymore:
    Some people just cut around the pieces where the hinges go, but I found that cutting along the entire piece made it fit much better because of the recessed hump for the spring assembly.
    3. Next I wiped down both surfaces with alcohol to make sure they were clean and free of debris or oil and then layed down a a few strips of 3M "extremely strong" double-sided tape on the console itself.
    4. Lastly, I placed the Got-It organizer on the double sided tape:
    Then I just placed the cover back on the console lid and VIOLA!!!! Perfect!
    The only thing I did notice is that, even with all the trimming, The lid does not fully close on its own. You have to press a bit to get it to latch, but it still works just fine and its not like I have to really force it down. I just didnt want to have to shave any more off the Grid-It in fear of messing up the structure for the elastic bands. Here is what it looks like before you press it closed:
    All in all a great mod for organizing your console. Very easy and definitely worth the money!!!
    Hopefully this helps anyone that has not done this yet. I know there are other posts about this, but I just thought I'd contribute.
  2. Sep 27, 2017 at 12:22 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    awesome write up! will be doing for sure
  3. Sep 28, 2017 at 8:25 AM
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    that looks awesome! I've seen threads on this before, but hadn't thought about it lately. NOW i am going to do this! Thanks! :)
  4. Sep 28, 2017 at 9:22 AM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Genius! Adding to my list. My center consol looks like a wreck in there.
    Trillcox likes this.
  5. Sep 28, 2017 at 10:44 AM
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    Just one note on this for some. (not saying anything bad about it). I did this recently and fond the weight of the organizer alone was too heavy. the door always wants to drop or close. Once i added anything too it that made it even heavier. meaning you can't open the lid and keep it open. it's going to always want to close on you (which i'm sure is not a big deal to some but i found it too annoying)
    So no big deal. just want you guys to realize this. Unless it was just my door for some reason be unbalanced.
  6. Sep 29, 2017 at 1:49 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    My "grid-it organizer" just came in the mail! Looking forward to installing after I do my sliders! Thanks for the write up, looks great!
  7. Oct 24, 2017 at 1:20 PM
    Trillcox
    Trillcox Active Member
    Christopher
    2006 Tacoma TRD
    Bone stock For now
    doing this mod tonight Wish my local staples had a gray one i guess black will work ! :benchpress:
  8. Oct 25, 2017 at 2:44 AM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Just an FYI, the center console organizer is on sale on Amazon for like $5 and some change with prime. Just ordered one
    stbear and Whitetrash like this.
  9. Oct 26, 2017 at 8:11 AM
    Trillcox
    Christopher
    2006 Tacoma TRD
    Bone stock For now
    This is for the OP how did you remove the Center-console?
  10. Apr 5, 2018 at 10:23 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I've had my OCD organizer and tray for a few months now and it bothered me that I couldn't get my hand into the larger middle section(center divider left out) so I modded the tray with some ABS. 6E470DF7-2211-4FA3-A403-C1F2AFC79410_zps_da2e0d84e28d06f7e205967b9d3e175098173b95.jpg
  11. Nov 13, 2018 at 1:52 PM
    skylerSurf
    skylerSurf Active Member
    Skyler
    2011 trd off road
    has anyone else given up on adhesive and just used screws?
    4x4cajun and hammertaco11 like this.
  12. Nov 13, 2018 at 2:42 PM
    BlueC0ma
    BlueC0ma Active Member
    07' TRD OR
    I glued my grid to a cut to fit piece of cardboard, then used the same tape as OP and it's help up great. I found the cardboards smoother surface kinda adhered better. Mines loaded too, holds a good bit of weight.
  13. Nov 13, 2018 at 6:34 PM
    General Zod
    General Zod Member
    New Harbor, ME
    2015 Access Cab, TRD OR, Blue Ribbon
    Hilux 4WD switch, bed liner, Hertz HCP-4 amp, Audison speakers and sub, Elka shocks, Dakar springs, mirror w temp
    I ended up using screws. Tried double faced tape first but in summer heat the tape wouldn't hold.
  14. May 23, 2020 at 9:35 AM
    chanka13
    chanka13 New Member
    Axel
    13' Tacoma Basic 5 Lugger
    17" rims
    just did this mod and looks great. Just a not, I only had to shave off one side of the grid, and only where the two swivel arms are so that it can close. about 3/4-1' in length. ALSO I slightly bent the grid so that it is curved towards me. It allows the grid to pop in and stay taught. Also the zipper in the back acts like a secret pocket.
  15. Feb 18, 2021 at 8:01 AM
    Tailleach
    Tailleach Member
    Tailleach (tai-yeck)
    NY
    08 TRD Access Cab
    Used ARE Topper - half livable accommodations to come
    This is amazing - just ordered the grid thingie - and I will install that ASAP. I hate not being able to find my knife, tape measure, flash light etc...rarely need to use them, but I have a bad habit of losing shit if said shit does not have a designated place1
    thanks!
    tcBob likes this.
