Center console organizer for Gen2 Tacoma
Discussion in 'Salex Organizers' started by salex, May 9, 2012.
  1. Feb 22, 2014 at 11:28 AM
    #421
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I really like mine. I know where everything is all the time now.
  2. Feb 22, 2014 at 12:07 PM
    #422
    Fletch
    Fletch Well-Known Member
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    man that is nice! i just might. :)
  3. Feb 22, 2014 at 1:57 PM
    #423
    ThomasMore66
    Dallas/Fort Worth & Durango
    I got the glove box and console organizer as soon as I bought my truck. Great product.
  4. Feb 22, 2014 at 2:12 PM
    #424
    firemanjay
    firemanjay Active Member
    Bristow, VA
    2014 Tacoma Off Road
    Got mine from Amazon
    great product
  5. Feb 24, 2014 at 7:32 AM
    #425
    rmojo
    rmojo Well-Known Member
    Ron
    Florida
    13 TRDOR 4x4
    sorry if someone posted a pic of this already, but can the glove box organizer take the weight of your factory manual sitting on top of it?
  6. Feb 24, 2014 at 8:47 AM
    #426
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Yes, no problem. My Toyota manual sits on the top shelf of the organizer.
  7. Feb 24, 2014 at 9:36 AM
    #427
    soccerkid
    soccerkid Member
    Lancaster, PA
    2014 Tacoma DBL CAB
    Just ordered one!
    Was looking at reviews on Amazon and they said it doesn't fit a 2014. Is that correct or will I be fine??
  8. Feb 24, 2014 at 9:39 AM
    #428
    rmojo
    Ron
    Florida
    13 TRDOR 4x4
    awesome, thank you!
    do you know if it takes the weight of the manual without the bottom compartments being full? I don't plan on packing the small bottom compartments, just putting a handful of things there.
  9. Feb 24, 2014 at 1:35 PM
    #429
    ThomasMore66
    My manual has been on top of mine since being installed, almost a year ago. My compartments below are not full. My manual is a little over stuffed so it sometimes catches a little bit when I open the glove box, but that's my fault. I put some extra things in there. I've thought a few times about using the box under the rear floor to hold the manual since I don't reference it much any more, but I've never done it. I did have to play with the GB organizer a bit to make sure I got everything installed in a slot. Once I did, and put it in the glove box it's been perfect.
  10. Feb 24, 2014 at 1:46 PM
    #430
    rmojo
    Ron
    Florida
    13 TRDOR 4x4
    cool, thanks man! definitely gonna order a set when I get the funds.
  11. Feb 24, 2014 at 1:47 PM
    #431
    firemanjay
    Bristow, VA
    I have the center console unit and it fits perfect
  12. Feb 24, 2014 at 5:32 PM
    #432
    salex
    salex [OP] Vehicle OCD by BaseLayer Vendor
    Illinois
    No worries on the 2014. Their have been no console changes since 2005.
    Selling on Amazon is great for business but tough in the customer service end. I put directions in the bag and they are ignored. I have an installation video on youtube and the website and that helps some. People just like to be mad and rant online I think. Any time I get a question I send the link to the video and problem solved.
  13. Feb 24, 2014 at 5:37 PM
    #433
    ThomasMore66
    Here's a quick pic of my glove box organizer with owners manual on top + some stuff and the somewhat empty lower compartments.
  14. Feb 24, 2014 at 6:31 PM
    #434
    salex
    Illinois
  15. Mar 10, 2014 at 11:05 PM
    #435
    Jpike
    Jpike Active Member
    Nh
    2014 trd off road
    just ordered the combo!
  16. Mar 11, 2014 at 2:02 PM
    #436
    Milan
    Milan Member
    Just installed mine. I am happy. I don't like how the middle two pieces move around so easily when trying to grab something out but overall, I am pleased. That big center console needs some organization.
  17. Mar 29, 2014 at 7:41 PM
    #437
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Just ordered the "Combo" to take advantage of the free shippping on Amazon,
  18. Mar 29, 2014 at 7:43 PM
    #438
    ThomasMore66
    I've never had that issue. Sure you got all the pieces together?
  19. Mar 29, 2014 at 7:56 PM
    #439
    DocD
    Mn./SoCal
    09 access cab
    I should have checked your web page, it would appear I could have saved a couple of bucks, Oh well, such is life!!
  20. Mar 29, 2014 at 8:12 PM
    #440
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Just ordered the Center Console organizer from ebay.
