center console removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by ScootsOFP, Sep 18, 2010.
  1. Sep 18, 2010 at 1:19 PM
    ScootsOFP
    ScootsOFP [OP] Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
    I'm looking for a guide that explains how to remove the center console trim so I can replace my radio with a new scion t1814. I've seen the guide on customtacos, but step 3 is confusing me. I'm not sure which screws its talking about in the ashtray. The vertically mounted ones, the ones way behind the ashtray through those holes, or where? Also, don't you have to disconnect the lighter to get the trim fully off?
  2. Sep 18, 2010 at 2:08 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    remove the 2 "pins" on either side of the bottom piece first, then pull that off.
    then..
    remove the 3 knobs for air
    remove the black cover behind them (just pull gently)
    remove the 1 screw on either side where that was mounted, just by looking you'll understand that part.
    then pull the whole piece away from the dash, the big black piece will come off, you'll have a bunch of connections to remove behind there, but that can all be done after you pull the piece off of the dash. then there should be a connection for the ashtray light, i leave that connected and let the piece hang.
    you will then be able to access the radio very easily!
    hope this helps without pics..
