Center console swap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jtmurph00, Mar 3, 2014.
  1. Mar 3, 2014 at 2:22 PM
    Jtmurph00
    Jtmurph00 [OP] Well-Known Member
    Hi, so I've read thru posts but haven't found a clear answer. I have a 2011 regular cab manual trans that did have a bench seat. I've already swapped out the bench for a set of buckets from an FJ cruiser and want to change the center console to a full length. I know the "top plate" around the gear shift is different but I'm wondering if that could be swapped so a console from an automatic would fit? Thanks
