Center Console Switch Panels
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Iggy, May 27, 2016.
  1. Jul 7, 2016 at 7:24 PM
    #41
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Another happy customer here :thumbsup:
    I painted it with spray on bed liner. I had some left over from my bumpers and I like the texture
    The blank that's left will hold my winch power switch. That'll be this weekends project.
    Sna and Iggy[OP] like this.
  2. Jul 8, 2016 at 11:55 AM
    #42
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Mine is shaping up a bit.
    I have to redo the paint... just put some dip on it for fun. It's also not even seated correctly and the switches aren't wired but it's fun to look at :D
    Oh yeah and I need to get a small enough torx to tighten the handles doh!
    thebaker and Iggy[OP] like this.
  3. Jul 8, 2016 at 12:11 PM
    #43
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Looking good guys!!
    @justchil let me know if you need any help wiring it up. I hope the diagrams I sent make sense.
  4. Jul 8, 2016 at 12:42 PM
    #44
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Hey thanks. Mine's all wired up. The diagram made it a snap. I even had enough sense to tap into the + & -on the ARB switches for the lights in the new ones.
    Hold on while I turn around for my pat on the back... :D
    Iggy[QUOTED][OP] likes this.
  5. Jul 10, 2016 at 1:54 PM
    #45
    justchil
    Andy
    WV
    13 AC TRD OR
    Super super happy. The two left switches are on/off/on (on/off /on with highbeam (s1) // on with reverse light (s2).
    Having trouble getting the panel to stay put. I'm not sure if maybe I should pull the cupholder thing put the panel in and put it back in... or if my paint is too thin to help hold it. The switchbacks behind the panel and the harness connector is pretty bulky so it may be causing the issue.
    I put 3-5 light coats of flat'ish black paint.
    :dancingbacon::dancingbacon::dancingbacon::dancingbacon:
    themanbearpig012 and Sleipnir like this.
  6. Jul 12, 2016 at 8:23 PM
    #46
    Iggy
    Northern CA
    Check out the build
    Quick question for you all. I'm looking to get these anodized in black so you guys don't have to paint them. It will increase the price about $5-6, is this something you all might be interested in?
    It will be a Type II with MIL certification.
    05TacomaORE likes this.
  7. Jul 12, 2016 at 8:31 PM
    #47
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I would've paid a few $ extra to not have to paint it. Hell, a can of spray paint costs that much... :thumbsup:
  8. Jul 12, 2016 at 8:38 PM
    #48
    justchil
    Andy
    WV
    13 AC TRD OR
    I would probably buy another one if it's anodized!
  9. Jul 17, 2016 at 12:44 AM
    #49
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    I need to know where and what switches you got going on in that setup!
  10. Jul 18, 2016 at 5:12 AM
    #50
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    So I'm pretty sure I need one of these, but what secures it in place? It's perfect since I need spots for switches, but don't know about losing the spot to throw my sh*t
  11. Jul 18, 2016 at 9:23 AM
    #51
    Iggy
    Northern CA
    Check out the build
    The panel is designed to use Carling switches. I get mine from http://www.otrattw.net/. The ones up above are commonly ordered from air on board.
    It's a snug fit, that really why the handles are there to help you install and remove the panel. I'm working on a more permanent mounting solution that will require disassembly and drilling of the center console.
  12. Jul 18, 2016 at 12:28 PM
    #52
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thanks. Now to decide what I want to do
  13. Aug 7, 2016 at 11:27 AM
    #53
    Trebor314
    Trebor314 Member
    Colorado
    2014 Tacoma XCab
    Hi Iggy,
    What is the RTMR full system. Someone else asked on a price and I didn't see a reply; what is it and what is your price?
  14. Aug 7, 2016 at 11:59 AM
    #54
    pogoface801
    pogoface801 Well-Known Member
    Sam
    Salt Lake City
    2009 Toyota Tacoma TRD
    Is there install instructions?? Also when will this be available for automatic again?
  15. Aug 8, 2016 at 4:38 PM
    #55
    Iggy
    Northern CA
    Check out the build
    I'm still working on the price for a full system. I should have that once I get this next batch of panels made.
    They are being made now! This next batch has been taking a bit longer dude to the amount of prep for anodizing. These are going to be awesome and worth the wait.
    scottalot likes this.
  16. Aug 9, 2016 at 6:07 AM
    #56
    RedTaco.
    RedTaco. Well-Known Member
    Sam
    2011 red pre runner
    3 in pro comp lift wearing 33x12.5 mud graps and 18x9 fuel throttles
  17. Aug 10, 2016 at 1:43 PM
    #57
    Eagle keeper
    Eagle keeper Well-Known Member
    Va. Beach
    2011 dcsb
    I'm in as well already Pm'd
    Iggy[OP] likes this.
  18. Aug 15, 2016 at 3:00 PM
    #58
    Iggy
    Northern CA
    Check out the build
    Ok guys! I should be getting these back from anodizing this week. Almost there, thanks for all your patience!
    Sleipnir likes this.
  19. Aug 17, 2016 at 10:21 AM
    #59
    Hojae84
    Hojae84 Well-Known Member
    Bedford NY
    2008 dcsb 4x4 sr5
    Curtis home pro, front rear cameras, side blind spot cameras and more
    Cool also in, pm a week or 2 ago
  20. Aug 17, 2016 at 9:13 PM
    #60
    Iggy
    Northern CA
    Check out the build
    I should pick up the batch today or tomorrow. I'll update stock on the website ASAP!
    ramonortiz55, thebaker and Overlanerd like this.
