Center console tray for Gen2....any interest?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by salex, May 10, 2017.
Would you be interested in the small Gen2 center console tray as shown for $10-$12?
  1. Yes
    84.6%
  2. No
    4.0%
  3. Maybe
    11.4%
  1. Aug 28, 2017 at 3:32 PM
    #141
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    No, you have it installed correctly. That's damn peculiar. Will have to wait for OP to chime in.
    UPDATE: I just went out and checked mine again, and by Gumby mine get's stuck too. Every time it opens I can tell it rubs just a bit but it does open, and then about every 5th time it gets stuck halfway like yours. Not a big deal to me but sounds like your tolerances are just smaller enough to cause it to happen every time for you. I imagine mine will wear down after a few uses and run smoother.
  2. Aug 28, 2017 at 4:15 PM
    #142
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Mine hangs up to, I was thinking it was my wet Okole console cover but once removed it still hangs up a bit. I'm just going to sand down that backside on the tray some and see if that helps.
  3. Aug 28, 2017 at 4:29 PM
    #143
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Just got mine. This is a lot more heavy duty than I thought it would be. It's made very well. Much happy!IMG_3272.jpg
  4. Aug 28, 2017 at 4:31 PM
    #144
    Windy
    Windy Member
    Mark
    NE Colo
    2011 TX Pro
    Mine is on it's way $15 including shipping off E Bay
  5. Aug 28, 2017 at 4:46 PM
    #145
    salex
    salex [OP] Vehicle OCD by BaseLayer Vendor
    Illinois
    Cost and simplicity. The notches are there to be able to spread the dividers far enough to put CDs in the middle. I know what you are going to say...CDs in 2017???
  6. Aug 28, 2017 at 4:49 PM
    #146
    horstuff
    horstuff Re-member
    PNW
    But can you make it hold one of these?
    or a few of these?
    Norton and salex[QUOTED][OP] like this.
  7. Aug 28, 2017 at 4:50 PM
    #147
    salex
    Illinois
    That looks like it is installed correctly as long as it is resting on the rim of the console. Does it take much effort to open the rest of the way?
  8. Aug 28, 2017 at 5:05 PM
    #148
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    No it doesnt take too much to push it open. I'm sure a couple passes with some sand paper will do the trick.
    salex[QUOTED][OP] likes this.
  9. Aug 28, 2017 at 6:03 PM
    #149
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Mine is here. A little trouble putting in the divider, did not want to seat all the way, the top wasn't smooth. Took it out and assembled outside, one of the supports seemed to fit better in the rear so take apart, noted which one went where and reassembled and it sits in just fine. Not sure I understand the square cutouts. I just put all the tiny stuff on the drivers side so they don't slide around and get lost.
    Now the tray was something else. I love the rubber matting, things don't slip when you grab them. Did not seem to work as I expected, did not slide like I thought it should, seems to shift and hang, not fitting well at all. Then dlawrence529 posted his pictures. Darn, I had it way too low and not sitting on the right spots, I see how it fits now and could not be happier. I could be, but that's because I put the things away and SHE did not get to give any input. I figure when she gets to detail the inside tomorrow things will change.
    Will give all star review, thanks for making these.
    Edit - checked the hang, once in 15 tries it came up half way.
    Edit 2 - Two 5 star reviews and might be the first to review the tray....
    dlawrence529 likes this.
  10. Aug 28, 2017 at 11:55 PM
    #150
    Goliath
    Goliath Well-Known Member
    Rhode Island
    2009 Access Cab TRD Sport
    Damn, real old school! Had a bunch of those in my day. I'd bet a bunch of youngins on here don't even know what they are. :rofl:
    Norton likes this.
  11. Aug 29, 2017 at 3:26 PM
    #151
    salex
    Illinois
    Thanks for the Amazon review! Enjoy those organizers on your trip.
  12. Aug 30, 2017 at 3:24 PM
    #152
    moondeath
    Pa, Gardners
    I left an Amazon review for your awesome tray! Little things like this make me :D.
    salex[OP] likes this.
  13. Aug 30, 2017 at 3:38 PM
    #153
    anonemoose
    Bill
    Big Pine, Calif
    We washed and detailed the truck this morning. She finally got to see it. At first she was "didn't get to add input" sort of sad face but by the time she was through with the inside and looking at it, thought it was one of the best things we could buy for organizing the clutter. So thanks again for something I didn't know existed but that I really needed.
  14. Aug 30, 2017 at 5:41 PM
    #154
    pineapplesteaktaco
    pineapplesteaktaco Active Member
    2013 Barcelona Red Tacoma
    I got all three pieces today. All fit with no issues. I left a review also on Amazon. Thanks for a solid product
  15. Aug 30, 2017 at 5:47 PM
    #155
    salex
    Illinois
    Good to hear. Thanks for the review!
