Center console wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolf13, Oct 12, 2009.
  1. Oct 12, 2009 at 3:56 PM
    wolf13
    wolf13 [OP] Well-Known Member
    IL
    2010 V6 4X4 Access cab TRD OR
    TRD Offroad w/Tow package. LEER 100XQ topper, painted grill surround, 08 cup holders, scangauge II
    I am trying to add a homelink like proshoppb did here. I am getting nowhere fast on finding a wire to tap into and proshoppb doesn't answer his pm's. Does anyone have an idea of where he tapped into for a power source or do I need to run a wire from somewhere int he dash?
  2. Oct 12, 2009 at 4:52 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I recommend yo use the 12v source from the auxiliary power receptacle (cig lighter).
    Follow these instructions to disassemble: DASH INSTRUCTIONS
    I extended 12 volts into the rear seating area of my truck using this method. I had to nearly take apart my whole dash do it properly. It looks much worse than it really is. It was my first time doing it so I took my time and got acquainted with everything.
    The split wire loom with the zip tie on it in this photo is my new 12 volt source in this picture:
    (power inverter under center console / arm rest on far left )
    I did this to add a 12 volt receptacle in the rear seating area
  3. Oct 12, 2009 at 5:02 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    nice mod there..^^^^
  4. Oct 12, 2009 at 5:33 PM
    SmootDog
    SmootDog Active Member
    Oklahoma
    2009 D-Cab TRD Sport 4x4
    I am sure there is a write up on how you wired your 120v receps into your console. Can you shoot me the link? That is kickass, and I am sure it would be easy if you know which wires are what.
  5. Oct 13, 2009 at 9:29 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Thank you.
    I learned much from all the writeups in the Cheap/free Mods thread.
    Here are direct links to, two writeups by Krookz which I followed to do the mods on my truck:If you read the "110 factory inverter - Always 400w" mod, make sure you go read all of the sources that Krookz cited, because there is additional info in there that I thought was helpful.
    There isn't a writeup on how to extend the 12 volts, that is something I just did when I had my dash apart and I observed that there was no suitable 12v source inside the center console.
    Also noteworthy was that there are cables that feed power to the inverter, but they are not powered unless the unit is powered. I used a multimeter and strangely enough the 8 gauge(ish) wire that feeds the inverter registered a fluctuating 1volt, but when the unit is powered it registers full 13.5 volts.
    If the inverter had 12 volts all the time, we could just tap into power there, but I couldn't so that's why I extended it back from the cig lighter.
    I hope that makes sense.
  6. Oct 13, 2009 at 10:16 AM
    SmootDog
    Oklahoma
    Perfect sense. I already added a constant 12 volt cig lighter up front, so extending will be no problem. I appreciate the input on the 110v stuff. That is what I want to add next. Thanks!!!!!!!
  7. Oct 13, 2009 at 10:22 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Very good. Glad to help.
  8. Oct 13, 2009 at 11:23 AM
    wolf13
    IL
    yes thank you, this is what i needed to know. what gauge is the 12v wire to the cig lighter and i'll pick up some taps tonight?
