Center Driveshaft Bearing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ticaz, Nov 11, 2020.
  1. Nov 11, 2020 at 4:45 PM
    ticaz
    ticaz [OP] Well-Known Member
    Dan
    2010 Timberland Mica DCLB 4x4
    Hey Folks!
    Quick question. I was under my truck yesterday greasing the u-joints in my driveline. I noticed my centre/carrier bearing has significantly more play than it used to. I can move the driveshaft in the bearing side to side probably over an inch.
    However, I have no symptoms. I don't notice any vibrations that usually indicate failure. The only thing I think I may be experiencing is it does clunk from time to time. Ive been chasing what I thought was a suspension clunk for a while, but everything I check is tight (Lower control/upper control arms, I recently replaced LBJ, leaf springs are tight, spare tire is snug, heck I even checked if a gas tank strap broke, and my tank was thumping around). I have a feeling I the clunk is from the driveshaft being repositioned when the rear suspension flexes and it makes contact. I could be way out to lunch on this, but curious if anybody has experienced similar symptoms?
    Regardless, I will be replacing the bearing, and have the part on order. I'll update this post if it fixes the problem when I get to it.
    Thanks in advance for any input.
  2. Nov 11, 2020 at 5:12 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Take pics of the repair as you do it and do a DIY
  3. Nov 11, 2020 at 5:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    ticaz[OP] likes this.
