center support bearing (again)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by edward79, Aug 3, 2016.
  1. Aug 3, 2016 at 12:53 PM
    edward79
    edward79 [OP] Member
    Edward
    2010 trd tacoma
    Well i finally made the change from ford ranger (i have had 5) to toyota tacoma, and i bought a 2010 trd with 70k on it, and got a good deal. well the center support bearing was bad, It was a replacement, so i changed it out with a dorman. That was a bad idea, the dorman after 10k was bad again (the rubber). So other than toyota, who makes a better one, i read about the urethane ones for rangers but mine is at stock height so i don't think the angles will work. My local store can get anchor #6074 or beck/arnlely 101-7912, but i am not opposed to ordering something somewhere else. just want something that will last. Seems like some off road place should make a good one. and one last question, why did toyota put such a weird angle on the drive shaft? most manufactures try to keep 2 piece shaft in somewhat of a strait line and it just doesn't seem engineered right the way the shaft is cocked to the passenger side at a downward angle.
    thanks
  2. Aug 10, 2016 at 7:04 PM
    Sholden223
    Sholden223 Keep it Squatchy
    Spencer
    Webster FL
    2011 SR5 4x4 SQUATCH EDITION
    6" Fabtech DB lift 2.5 Dirt Logic coil over w/resi, 35's Toyo M/T, 18" Ballistic Sythe wheels, 2.5 Dirt 52" OSRAM LED light bar with Relentless Fabrication mounts, straight glass pack exhaust dumped at the axle, HID smoked fog lights, HID smoked headlights with halos and LEDs, Black low profile toolbox, Sasquatch Lightbar button, Rough Country pods
