Center Support Bearing
Discussion in 'Technical Chat' started by 05TacoTRD, Feb 21, 2013.
  1. Feb 21, 2013 at 5:28 AM
    05TacoTRD
    05TacoTRD [OP] Member
    Franco
    Bradenton FL
    05 PreRunner TRD Sport
    Has anyone had issues with their Center Support Bearing? I just replaced mine about 2 months ago, and all was well...Now it seems as if the similar vibration it had is slowly coming back...:confused: Is this a common issue? I have a 05 Double Cab Long Bed Pre-Runner... Any Ideas on what can cause this to go bad so quick? It's currently all stock no mods yet... Any advice will help, Thanks!!
  2. Feb 21, 2013 at 5:30 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    Check the real wheel bearings, take out the driveshaft and spin the rear wheels. You might have a bad bearing rather than the carrier going out again.
  3. Feb 21, 2013 at 5:50 AM
    05TacoTRD
    Franco
    Bradenton FL
    Ok, I will check that out... I did run it on stands and heard a scrubbing sound... I'm pretty sure the left rear axle is slightly bent from a previous accident if the bearing is bad I bet thats why
