Central Alabama Meet!
Discussion in 'South East' started by travis9287, May 20, 2011.
  1. Jun 3, 2011 at 1:34 PM
    #101
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    which style coil compressor you want? the one that goes down the center of the coil or the one that has two pieces that attach to the outside of the springs and you crank down. ill get either. rem i used to work for both autozone and advance. so i can pick it up fri or sat morning and return it when i get back in town. may not even take a deposit if the right person is working at advance that day.
  2. Jun 3, 2011 at 2:13 PM
    #102
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Can you not get the coils mounted on shocks separately before doing the install?
  3. Jun 3, 2011 at 2:25 PM
    #103
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    No preference from me.
  4. Jun 3, 2011 at 2:26 PM
    #104
    TacoFMS
    Justin
    Louisa County, VA
    i dont have a spare set of the top plates for the strut assembly. unless you got some floating around?????
  5. Jun 3, 2011 at 3:23 PM
    #105
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    get the ones that mount on the outside, and get an impact wrench. otherwise your hand will be super sore by the end of the day
  6. Jun 3, 2011 at 3:53 PM
    #106
    TacoFMS
    Justin
    Louisa County, VA
    thanks paul. ive got a 3/8 and 1/2 drive impact ill bring both.
  7. Jun 3, 2011 at 5:36 PM
    #107
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    Yes sir! This will save probably a total of an hour because the threads on the compressor are super tight and take forever to wrench down! Don't forget to wrench evenly though...
    If you and Brian have room for one more to show up i might show up for a little bit...
  8. Jun 4, 2011 at 6:57 AM
    #108
    TacoFMS
    Justin
    Louisa County, VA
    Hey paul did you have a spare set of top plates that you used or did you reuse the ones on your truck? just wondering so if you reused i can ask you a thousand questions about taking those off and putting the new ones together, cus that looks like the route im gonna have to take. went to several parts stores last night and noone sells that top plate or at least its not called that. was gonna just buy 2 new ones so they could be put together before i went up to brian's.
  9. Jun 4, 2011 at 12:06 PM
    #109
    FlawedXJ
    Paul
    NorAla
    i reused the stock ones. I do believe they are 90 bucks a piece from toyota. eff that. start compressing the coil and voila, take the top plate off. that easy.
  10. Jun 4, 2011 at 2:37 PM
    #110
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Did one today.. 2 key notes to make.. If your doing your rear to then BE SURE to lift your truck high enough!!! When compressing the coils MAKE DAMN SURE you have an impact gun worth a damn!! If not.. well extend out your normal work time by 2 hours!
  11. Jun 4, 2011 at 4:09 PM
    #111
    FlawedXJ
    Paul
    NorAla
    i have a shitty battery powered impact gun and it worked fine for me?
  12. Jun 4, 2011 at 5:00 PM
    #112
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Well you're awesome! Cause this thing we used today took forever to clamp those coils down...
  13. Jun 4, 2011 at 5:17 PM
    #113
    FlawedXJ
    Paul
    NorAla
    its about 15-20 minutes of back and forth between the two bolts. My 886's were so stiff the bolts were flexing to the point they bent in and touched the coil itself.
  14. Jun 4, 2011 at 5:20 PM
    #114
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Yeah these stock ones today were making them bend outward! Really scary if you think about it.. It took us forever though.. I don't know what the problem was...
  15. Jun 4, 2011 at 5:21 PM
    #115
    FlawedXJ
    Paul
    NorAla
    whose coils were you changing?
  16. Jun 4, 2011 at 5:24 PM
    #116
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Me and Daniel swapped out his factory coils onto some Bilstiens for his 04'.. It was fun though.. That's where we also learned the more lift you have the easier it is to do the rear AAL..
  17. Jun 6, 2011 at 11:49 AM
    #117
    TacoFMS
    Justin
    Louisa County, VA
    did we run everyone off again? is the meet still on? how did drgonzo get so much rep in only 15 posts??? am i asking too many questions??? what is your favorite color?
  18. Jun 6, 2011 at 1:14 PM
    #118
    KEG'sTACO
    KEG'sTACO FJ Cruiser
    Kurt
    Auburn, AL
    '08 FJ Cruiser
    Leveled, 33" BFG A/Ts, Demello Offroad front flat-top bumper, Demello Offroad rear 3-piece bumper, 17" Liquid Metal Gatlins, Pioneer audio upgrade, custom mounted 10" subwoofer, offroad interior
  19. Jun 6, 2011 at 1:21 PM
    #119
    TacoFMS
    Justin
    Louisa County, VA
    well that doesnt answer any of my questions keg!!!
  20. Jun 6, 2011 at 3:49 PM
    #120
    FlawedXJ
    Paul
    NorAla
    Kurt, think he who shall not be named will have his front axle by then?
