Centre console armrest sore elbow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mainjet, Oct 14, 2019.
  1. Oct 14, 2019 at 10:31 AM
    mainjet
    mainjet [OP] Well-Known Member
    Alberta
    2019 Tacoma off road
    Ray 10s Diode dynamics Hidden Light bar Toyo AT2s
    So it’s just the way I drive, I rest my elbow on the centre console for support.
    I developed this habit from my old ford and when I sold that truck it literally had a hole worn out of the cover from my boney elbow.
    The new Tacoma cover felt like resting it on a cinder block.
    So I decided to remove the cover as you can see by the picture there might be 1/4 of foam under it.
    So I decided to give these guys a try
    https://www.redlinegoods.com/landin...MI_-W1z5-c5QIVsx-tBh2EvgogEAMYAyAAEgLz0vD_BwE
    It was a little harder to install than expected but I think it turned out good and it comes with foam that’s a whole lot thicker
    I went with the 6/8 of an inch and it’s perfect for me but they do offer the 1 1/8” option also
    I would not advise doing this mod if your not comfortable working with spray glue
    I have redone enough dirt bike seat covers in my life which does not require spray glue and this was one step harder.
    How the product is sent to you.
    Glued to the existing armrest.
    Finished product install.
    I should add I still have the factory cover
    The new cover gets glued to the plastic sides of the console.
    When this one stops looking good I can easily remove and reinstall the factory one as it has no glue holding it on.
  2. Oct 14, 2019 at 10:38 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    May I have a Mars bar, sir?
    mainjet[OP] likes this.
  3. Oct 14, 2019 at 10:39 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nice. My center feels awfully thin as well.
  4. Oct 14, 2019 at 10:39 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    I have the same issue. My Jeep was comfy. This my elbow gets a pressure point pain since there’s no padding. Looks good
  5. Oct 15, 2019 at 4:31 PM
    mainjet
    Alberta
    This will fix that I suffered from the same thing
    Did a long trip on the weekend which made me feel even better about the mod
  6. Oct 15, 2019 at 4:44 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Oct 15, 2019 at 5:00 PM
    ICU1
    ICU1 Well-Known Member
    Best mod ever. Amazon. It’s gelled filled.
  8. Oct 15, 2019 at 5:21 PM
    gclyne
    gclyne Well-Known Member
    Grant
    Indiana
    2004 TRD Off-Road- 3.4L
    Are those seat covers you have or just the OEM leather seats? The seats look nice as well! Thanks for sharing.
  9. Oct 15, 2019 at 6:46 PM
    mainjet
    Alberta
