Centre tire tread ware
Discussion in 'Wheels & Tires' started by Gaudet2010Tacoma, Apr 30, 2021.
  1. Apr 30, 2021 at 1:59 PM
    Gaudet2010Tacoma
    Gaudet2010Tacoma [OP] Member
    Michael
    2016 3rd Gen Tacoma TRD Sport
    2" front leveling kit
    Hello, does anyone know what would cause this and how to make sure it doesn't happen again? This happened to both my rear tires in just 5 months.
  2. Apr 30, 2021 at 2:04 PM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    So I could be very wrong about this but I remember hearing over inflation can cause this.
  3. Apr 30, 2021 at 2:05 PM
    H20man
    H20man USCG Polar Star WAGB-10
    The Rainy State
    2001 Tacoma Ext Cab 4x4 2.7L 5spd
    Bone Stock
    Correct.
  4. Apr 30, 2021 at 2:09 PM
    Gaudet2010Tacoma
    Michael
    I got them put on rims and installed at canadian tire, not impressed.
  5. Apr 30, 2021 at 2:11 PM
    TechLizard
    TechLizard Well-Known Member
    Southern California
    '21 ACMT
    Ditto, verify the air pressure in those tires.
    Which Way Out likes this.
  6. Apr 30, 2021 at 2:11 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    You have to check your tire pressure man, like every other tank full of gas. You killing your tires not paying any attention to them.
  7. Apr 30, 2021 at 2:12 PM
    Gregero
    Greg
    Carson City, NV
    Sorry, man :( I'd be not happy as well. Definitely check the fronts psi as you rotate them to the back.
  8. Apr 30, 2021 at 2:16 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Most tire shops fill the tire by the tire spec. Not the spec of the vehicle there being mounted on.
    No doubt they were over inflated by the shop, but as an owner and operator of the vehicle these things need to be watched and adjusted accordingly.
    RedWings44 likes this.
  9. Apr 30, 2021 at 2:28 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    As everyone says, tire pressure. Don't assume the tire shops (or dealerships) fill them properly. My dealership often inflates them to 5-10 PSI over the cold recommendation.
    Also bear in mind that a tire filled to 30 PSI in December will likely not be at 30 PSI in April, especially if it is warm outside. Air naturally escapes through the rubber. However, heat also causes expansion. You can also observe this when driving if you use the PSI readout on the dash or check the pressures after a drive.
  10. Apr 30, 2021 at 2:28 PM
    Gaudet2010Tacoma
    Michael
    Yea ill definitely be keeping an eye on them closer. I checked the psi and they're all the same 28psi on all four. Any suggestions on the psi?
  11. Apr 30, 2021 at 2:30 PM
    RedWings44
    Michigan
    Check the B pillar on the driver's door opening. That has the minimum recommended cold PSI.
    Edit: also, if you click "quote" in the bottom right, the person you're replying to will get a notification.
  12. Apr 30, 2021 at 2:30 PM
    Gearheadesw
    Davenport Fl
    Start at 32 psi, and don't forget to rotate at 10000 miles ish for tire longevity.
  13. Apr 30, 2021 at 2:36 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    28 psi would not cause that extreme of wear in the middle.
    When was the last time you had an alignment?
    EDIT: Oh, rear tires. Hmmmm. Is it the same amount of bad wear all the way around hte tire?
  14. Apr 30, 2021 at 2:42 PM
    Gaudet2010Tacoma
    Michael
    Yes, same wear on both rear tires.
  15. Apr 30, 2021 at 2:44 PM
    0xDEADBEEF
    How are the front wearing? And same air pressure the whole time?
  16. Apr 30, 2021 at 2:45 PM
    Gaudet2010Tacoma
    Michael
    Same air pressure. The front ones still look brand new.
  17. Apr 30, 2021 at 2:48 PM
    RedWings44
    Michigan
    Those also look like winter tires. They'll definitely have more wear than regular tires, especially in warmer weather.
  18. Apr 30, 2021 at 2:49 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I understand you're not being impressed, but I sure hope you're not surprised!
  19. Apr 30, 2021 at 2:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Google “tire chalk test”
  20. Apr 30, 2021 at 2:49 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Do the chalk test to make sure you have even wear and adjust psi accordingly.
