Ceramic Bearings? Anyone try them.
Discussion in 'Performance and Tuning' started by StuckinOhio, Mar 23, 2016.
  1. Mar 23, 2016 at 9:14 AM
    StuckinOhio
    StuckinOhio [OP] Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Planning on installing my NST pulleys soon.
    Was planning on installing a new gates belt as well.
    From what I've read it has been suggested to clean all the pulleys when installing a new belt.
    Since the belt will be off and pulleys will get cleaned, it would be a good time to check for bearing play etc.
    My question is has anyone tried installing ceramic bearings into the Idlers?
    This is only and idea to further reduce engine load from accessories, but with 4 idlers all siphoning power after 70K of use.
    Ceramics are suppose to reduce drag and last longer etc.
    Anyone have experience with them? even non-automotive related?
  2. Mar 23, 2016 at 10:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Micro Blue Bearings has ceramic bearings.
  3. Mar 23, 2016 at 11:43 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Do you have any knowledge of people using ceramic bearings for this application?
    It's $260 for a set of (4) microblue ceramics. I know ceramics are a big deal in the bicycle community. Just wasn't sure if there was actual data to support a more apples to apples comparison.
  4. Mar 23, 2016 at 12:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I used one for my pilot bearing, from them. You have to self pack them.
    All I can say is that I have thought about it, but never gotten around to it.
