Ceramic coating
Discussion in 'Detailing' started by KnckleChldrn, Feb 20, 2018.
  1. Mar 1, 2018 at 4:24 PM
    KnckleChldrn
    KnckleChldrn [OP] Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    Thanks for all the tips. As soon as there’s good weather on a day off I’ll try this out. Don’t have a garage though so will be doing outdoor. Also I’d be doing on a 17 with about 5k miles. I’ve never waxed it and have only taken through 1 dealership car wash. A clay bar application shouldn’t be needed right? A good wash, little touch up polish and good to go?
  2. Mar 1, 2018 at 5:35 PM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    I would still clay it. You would be surprised what gets embedded in new car paint during the shipping process.
    ace96 and Sterling_vH111 like this.
  3. Mar 1, 2018 at 5:41 PM
    KnckleChldrn
    Jamie
    Mass
    Ok. Haven’t coated before either haha. Can’t mess that up right?
  4. Mar 1, 2018 at 5:58 PM
    AMarkham40
    Roanoke, Virginia
    Haha. I haven't went down the coating road either. Optimum Opti-Seal every 6 months & Optimum Car Wax after every wash is my routine. I may try a coating one day though.
  5. Mar 1, 2018 at 7:38 PM
    KnckleChldrn
    Jamie
    Mass
    Damn auto correct. I meant to say I’ve never clay barred before*
  6. Mar 1, 2018 at 10:58 PM
    AMarkham40
    Roanoke, Virginia
    Just make sure you are using light pressure & spraying a good lubricant so the clay bar glides across the paint. You don't want it to grab the paint.
  7. Mar 2, 2018 at 2:43 AM
    KnckleChldrn
    Jamie
    Mass
    Thanks for the advice.
    AMarkham40[QUOTED] likes this.
  8. Mar 6, 2018 at 5:55 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    My rule is I always clay before any “buffing” motion.
    If I’m doing anything but drying the truck, it gets clayed. Which for me is twice a year. I always pull up a considerable amount of filth each time.
  9. Mar 6, 2018 at 5:59 AM
    KnckleChldrn
    Jamie
    Mass
    Good to know. I’ve never clayed. Can’t wait for nice weather to try this out.
  10. Mar 7, 2018 at 7:50 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Stick with a coating that is user friendly since this will be your first time. By user friendly I mean something that is forgiving during the application process and removable via a polishing compound & Dual Action Polisher if something goes wrong. A few of those have already been mentioned here. A common mistake when first using coatings is applying too much in one area which results in high spots. These are visible areas where it looks like the product is raised up above the surface you applied it to. In some extreme cases you can feel them with your finger once the product has cured fully. Here is a link that helps explain that better and what is involved to remove those spots so try and avoid this by simply taking your time and not using too much product in one area: https://www.autogeekonline.net/foru...questions-/55035-opti-coat-high-spot-fix.html
    You'll will get the most out of your coating by spending your time cleaning the paint and correcting/polishing before applying. As mentioned claying will remove contaminants our eyes cannot see. Spending time correcting existing scratches/swirls followed by polishing will allow your paint to look its best and the gloss effect from the coating to really stand out.
    IMHO Opti-Gloss 2.0 would be a great product for the first timer to use. It has fantastic durability and certainly leaves the paint looking "just waxed" after every wash.
    You should go for Opti-Gloss since you're already familiar with their other products. They all work together and you could still apply Opti-Seal every six months to help boost the base coat and bring out the paint's gloss. Also Optimum No-Rinse is safe to use especially with a base layer or opti-gloss and/or opti-seal.
  11. Mar 13, 2018 at 5:37 PM
    808leo
    808leo Well-Known Member
    Kapolei, Oahu
    ‘21 super white dcsb 4wd
    5100 max setting, 285/70/17 ko2, FN 6 shooter, Subaru/kicker tweeters, JBL BassPro sub, nfabs, LED lights exterior/interior.
    I just applied opti high gloss coating for the first time and it’s so easy. It’s just the prep that’s a bitch. After I did a sedan my girl wanted me to do her HONDA. I keep her CRV cherry and even that it took me 7 hours to prep and coat. I suggest doing two coats if you do opti high gloss. Considerable amount more gloss imo
    WebberLander likes this.
  12. Mar 14, 2018 at 3:01 PM
    pinktaco808
    pinktaco808 Hot Steppa
    new rides
