Ceramic Coatings/Wax
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Older'n Dirt, Aug 13, 2020.
  1. Sep 14, 2020 at 9:27 AM
    #61
    Hold The Gauc
    Hold The Gauc Before we get started, does anyone wanna get out?
    I will never financially recover from this
    Thanks, time I look into ceramic...
    Junkhead[QUOTED] likes this.
  2. Sep 14, 2020 at 9:31 AM
    #62
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Ceramic is the way to go 100%. Ive been detailing my own cars since i was 16 and all but 1 were black. Im never going back to wax/sealant. If you can do it yourself, you will save about a grand.
    Hold The Gauc[QUOTED] likes this.
  3. Sep 14, 2020 at 9:38 AM
    #63
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    From what i understand not all ceramic treatments are equal. The professionally applied simonize glass treatment plan i had done took most the day. When finished the finish on the truck looked and felt like a thin hard coat of glass. After more than 6 months of not washing, or doing anything to the truck, it still looks the same.
    Hold The Gauc likes this.
  4. Sep 14, 2020 at 10:51 AM
    #64
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I use these three Meguiar's products and am very please with he results.
  5. Sep 14, 2020 at 10:52 AM
    #65
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Wow, that corvette.:drool:
    Kevin Jones[QUOTED] likes this.
  6. Sep 14, 2020 at 1:51 PM
    #66
    QwickC
    QwickC Well-Known Member
    OH
    2017 Silver Tacoma TRD OR
    I prefer ceramic coating on my cars, have used several brands. Just did paint correction on Tacoma topped with Kamikaze ISM 1.0 ceramic coating. Nice to be able to coat truck, trim an plastics all at same time. I do like a nice sealant though and have used several an keep them on hand for details, even home appliances. Sealants, Polish Angel sealant an wax, Wolfgang dgps, Conolite 845, FK1000. Spray sealants Kamikaze Over Coat, Rupes, Wolfgang dgps, Carpro reload, gyeon can coat(actually listed as coating) are just some I've used. Meguiars D15601 Synthetic X-Press Spray Wax this stuff is like Franks hot sauce.
  7. Sep 14, 2020 at 3:32 PM
    #67
    zoo truck
    None
    I use use that mequiar's yellow snot wash/wax on the old tundra when it came out...leaves a nice clean shiny finish but doesn't last too long.
  8. Sep 14, 2020 at 3:42 PM
    #68
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Cquartz UK 3.0
    202 Black , When it is put on the Lexus vehicles it is called "Black Onyx"
    IMHO the best Gloss Black out there for the eye in depth.
    It is also THE WORST for showing ANYTHING.
    I mean if a fly farts in 10 paces... you'll see a spec.
    Truck is a 2017 and has been outdoors 364 days of every year.
    Sees winter salt and sand, trails.
    Goes through a touchless carwash regularly.
    Looks BETTER than when it was on the lot brand new and this is almost 3 years later.
    You'll have a tough time even finding a swirl mark.
    Before I go on trails I also put a thick coat of wax on the sides of the truck.
    The wax and the ceramic coating has prevented trail rash so far! But I do avoid big branches.
    The harder coating and the lubrication from the wax seems to help the minor branches and twigs to slide over without digging in. (knock on wood)
    I spent 2 days on paint correction to get it perfect,
    then used Cquartz Elixer then Cquartz UK 3.0
    5 Coats over 2 days in the spring when it was below 70degF outside in a shaded area.
    Real easy to apply, just like waxing your truck.
    I had tried waxes on it. Forget that they don't last and are "soft" but they did not give a look like the truck was coated in glass with a glossy "depth".
    The first coat was dramatic, each coat added "depth".
    Here are some tips for Cquartz UK 3.0
    The cooler it is the longer you will have to work with it,
    I could do half my hood or a whole fender/panel before wiping it off when the temp was 10deg C (approx 50F),
    Use less on the applicator than what they tell you (1/2 - 3/4 of a line) and wipe out and area in a criss cross pattern until you feel the applicator is meeting more resistance.
    That is when it is starting to flash and also wastes less on your buff cloth (which you will throw out as once it hardens it will scratch)
    Buff off lightly and more than you think you should as once any haze hardens you have to polish it pack out (which is easy BTW).
    It's easier than you think. Seriously.
    QwickC likes this.
  9. Sep 14, 2020 at 3:48 PM
    #69
    Kevin Jones
    Kevin
    Va
    It's primary a car wash, so I don't believe it's really meant to give a 'long lasting' shine. But more to clean well while supporting/protecting your waxed finish by not removing it.
  10. Sep 30, 2020 at 4:50 PM
    #70
    jmichael99
    jmichael99 Well-Known Member
    WV
    I bought two packs. I like the union on the left side of the flag.
  11. Sep 30, 2020 at 5:07 PM
    #71
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Old fashioned simonize been hard to beat on my 67 SS IMG_20200820_184749733.jpg
    zoo truck and daks like this.
  12. Sep 30, 2020 at 5:28 PM
    #72
    Gus
    Gus Well-Known Member
    Wayne, Pa.
    2020 Access Cab SR Utility Package Barcelona Red
    Rear sliding window, intermittent wiper switch, center console tray, glove box organizer shelf, WeatherTech front mats and mud flaps, 3D MaxSpider behind-the-front-seats mat, bed lights, MESO climate control rings, XPEL tailgate protection, Desertdoesit.com seat jackers, RAV4 radio knobs, glove box letters.
    Wow, my Dad swore by the 'yellow' can of Simoniz but I never liked using it because it was hard to work with or so I thought as a teenager. I used to use Liquid Glass alot...
    I'd like to try something before winter that will last till spring but doubt there's anything for that. I have access to a heated garage at work but getting the truck clean enough to wax is my challenge during the cold months.
  13. Oct 7, 2020 at 5:45 AM
    #73
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    As I was waxing (poetic) after washing the truck this past weekend and using the Hybrid Ceramic made from little green turtles, I was wondering if it would make any sort of difference to apply the coating to frame parts.
    For some of us that haven't gone through winter hell yet, the frames are still in decent shape and painted. If the ceramic coating is super hydrophobic, it should seal in the paint and whatever else from further oxidation.
    Proper prep would be damn near impossible but could it hypothetically get you through winter. And so begins a Friday thread on humpday...
    Aaronparker001 likes this.
