CerClunk in rear suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by out_of_step, Oct 24, 2008.
  1. Oct 24, 2008 at 2:34 PM
    out_of_step
    out_of_step [OP] Member
    colorado
    07 Tacoma TRD V6 SR5
    I just got and 07 Acces Cab V6, 6speed, TRD/SR5, 39000 mi on it, When driving on bumpy roads at slow or high speeds there seems to be a clunk coming from the rear suspension, im not sure if this is normal or not, but I have visually inspected it and couldn't find anything, I don't believe its the spare tire because it solidly tightened up. its also completely stock, if anyone has in suggestions let me know.:confused:
  2. Oct 24, 2008 at 3:01 PM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    Maybe it's the suspension bottoming out on the bump stops? Do you have the rear suspension TSB?
  3. Oct 24, 2008 at 3:27 PM
    out_of_step
    colorado
    not sure, just gonna cross my fingers I do because its passed the mileage on warranty. Does anyone know where the part number is located on the spring itself so i can check to see if its been upgraded?
  4. Oct 24, 2008 at 6:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have the TSB springs, there will be 3 leaves, plus an overload spring. If you have the TSB springs, and the stock shocks, its possible you are "topping out" the stock shocks.
  5. Oct 24, 2008 at 8:30 PM
    out_of_step
    colorado
    well i'm kinda bummed out because I only have 3 leafs in the spring total, so this probably shows it hasn't been fixed,(unless the TSB for the TRD suspension has different amount of leafs) damn this sucks I just bought this truck with 39000 mi, does anyone know how much it would cost me to get this fixed since it wouldn't be covered under the comprehensive warranty?
