Cetme rifle
Discussion in 'Guns & Hunting' started by Bill Brasky, Feb 24, 2009.
  1. Feb 24, 2009 at 7:06 PM
    Bill Brasky
    Bill Brasky [OP] Well-Known Member
    East of the Mississippi, South of the Ohio
    stump jumper
    modified for light trail use
    Found one for $500. Looks good. Green furniture. But I have no idea what I'm looking at.
    Thoughts? Is it worth it? Decent rifle?
  2. Feb 24, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I hear mixed reports on the CETME's. For $500.00 though...sounds like a good deal.
  3. Feb 24, 2009 at 7:42 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    German designed IIRC; probably a good rifle.
  4. Feb 25, 2009 at 4:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bill, Did you check out AR15.com and see what they said?
  5. Feb 25, 2009 at 4:59 AM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    There are several things on a cetme you need to be aware of. they are a copy of the HK-91. You should take a good look at the charging handle tube, what kinda metal is it made out of, what kinda metal the receiver is made out of, Is the bolt face ground or not? what size gap is there between the bolt and carrier (look at it thru the mag well. these rifles are prone to malfunction,but can be made to work great with a little effort. these rifles three years ago went for $250, compared to the HK-91 which sells for around $1800-$2600. If you can take several pics of one i can check it out for you if you want the rifle. When I get home i can link several websites for you full on info. on these rifles. The HK-91 has none of the issues its copy has.
  6. Feb 25, 2009 at 5:49 AM
    Bill Brasky
    stump jumper
    No, not yet. I just remember reading that the Cetme was the lesser of the HK rifle clones...but a .308 semi-auto for $500 requirs some thought.
  7. Feb 25, 2009 at 5:56 AM
    Bill Brasky
    stump jumper
    Thanks a ton.
    What type(s) of metal should I be looking for in the charging handle tube and receiver? And the ground bolt face...is that a modification to the weapon by the owner? And am I just looking for machining marks? And, how big (or little) should the gap be?
    Again, thanks for the info.
  8. Feb 25, 2009 at 6:08 AM
    Cobra69
    You want stainless steel in both, the bolt face should NOT be ground if it is there was a feeding and function problem with the rifle. It may work now,but you may have problems or issues with it. I'll have to get back to you on the gap. Its at home I'm at work.
  9. Feb 25, 2009 at 1:05 PM
    Cobra69
  10. Feb 25, 2009 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My Buddy has a Cetme that had FTF's all day long. He had a knowlegable Cetme dude fix it up, and now its 100%. Seems the most common issues are feeding and cycling, but a good gunsmith should be able to fix that.
  11. Feb 25, 2009 at 3:32 PM
    Cobra69
    yup very true.......I have seen about 10 of them that had that problem. My buddy bought 5 in a row with that problem before he gave up.
