Chain question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redgrom, Dec 27, 2010.
  1. Dec 27, 2010 at 10:48 AM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    hello, kind of a stupid question but thought I would ask. Is it best to install chains on the rear wheels in 4x4's? I have always put them on the rear in the past, but last time I slid out and wonder if I had traction on the front wheels if I would have fared better?
  2. Dec 27, 2010 at 10:57 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Rears! And if you're stock, they won't fit on the front anyway (might want to read your owners manual).
  3. Dec 27, 2010 at 10:57 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
  4. Dec 27, 2010 at 12:09 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Rear is where I'd run 'em.
  5. Dec 27, 2010 at 12:11 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    check your manual. stock trucks cannot run chains on the front.
  6. Dec 27, 2010 at 1:15 PM
    Redgrom
    Brent
    san clemente
    Thanks for the replys, Stock set up was gone long ago and after a cab mount chop I have tons o room.
  7. Dec 27, 2010 at 1:18 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    If your lifted I would run them on both the front and rear. It'll help your steer better.
  8. Dec 27, 2010 at 3:13 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    I have run cables on the front of a stock setup trying to climb up out of a ditch. It's tight but it Will work on a stock rig.
  9. Dec 27, 2010 at 3:37 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Front and rear, go anywhere!
  10. Dec 27, 2010 at 3:46 PM
    Redgrom
    Brent
    san clemente
    Just did a test fit and have plenty of room, checked the upper and lower arms and don't see a issue. I will probably just stick to the rear and see how dura trac's hook up in the snow. If its pretty bad I might use the front but only as a last resort.
  11. Dec 27, 2010 at 4:10 PM
    paul2010trd
    paul2010trd New Member
    Paul
    Delaware
    2010 DC TRD
    Really bright fogs (9005) anytime, Locker anytime
    I have to say ALL 4 wheels. We have to be able to speed up, slow down & turn. I don't care what it says in the manual
    Having said that... I bought two sets of chains. I did not think of possible clearance issues. The chains I got don't clear the UCA's. My truck is a bone stock 2010 TRD with BFG Rugged Trail 265/75R16's. My father-in-law has a 2007 Tacoma SR5 with 245's. He uses chains on all four when going up a steep trail, which is always icy in winter because of springs, to his cabin near the top of a mountain in northern PA. I'll be getting Spidertrax wheel spacers soon so I can put the chains on the front. Hopefully it will snow more so I need them, driving around on dry pavement with chains is a bit bumpy!
  12. Dec 27, 2010 at 4:14 PM
    Redgrom
    Brent
    san clemente
    I should be clear I have cables not actual chains. I might try to find a second set locally tonight before I head out just in case. I have to imagine if I have all 4 tires warped up I should be good. But truthfully i would rather avoid that much snow.
  13. Dec 27, 2010 at 4:17 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    Good luck & stay safe!:D
