Chain Recommendation's?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatOneYotaGuy, Dec 19, 2016.
  1. Dec 19, 2016 at 3:46 PM
    ThatOneYotaGuy
    ThatOneYotaGuy [OP] Active Member
    Aaron
    2017 Tacoma Off-road
    Looking for chain recommendations for 17 TRD Off road... 265/70-16. It doesn't look like there are many options. Right now I'm looking at the zt741's cause I can get them cheap. Want to buy two sets, front and rear. But have heard cables don't do as good as chains. Any one have personal experience.. what are you running?
  2. Dec 19, 2016 at 3:49 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Cables don't perform as well as chains but they are much smoother to drive with and don't require a lot of clearance. I run cables on my wifes AT jeep tires and Chains on my Tacoma MT tires.
  3. Dec 19, 2016 at 4:11 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Don't have brand preference, but I run cables just because they are quicker to put on. I have had to use chains maybe 3x in my life so I don't need anything super heavy duty.
  4. Dec 19, 2016 at 4:48 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Aaron:
    You'll note in the manual that it says not to put chains on the front. If you stick your head under and take a look, you'll understand why. There is little-to-no room.
    I've never owned a set of cables so perhaps they'll fit. I tried my old V-Bar chains from my 2007 SR5 and they didn't fit my 2016 TRD OR. So I bought a set of these: http://www.etrailer.com/Tire_Chains/Titan_Chain/TC2828CAM.html
    I have yet to see if they fit. When I do, I'll put them in the chain box and hope to never need them.
    SB
  5. Dec 19, 2016 at 6:28 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Chains forever. Don't run them in the front. If you intend to use them don't buy cheap. If you are buying them because its the law then cheap is probably ok.
    monsterkx2fiddy likes this.
  6. Dec 19, 2016 at 7:01 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Those autosock traction covers look interesting... can probably run those upnfront with chains in the back, but pricey.
  7. Dec 19, 2016 at 7:37 PM
    ThatOneYotaGuy
    Aaron
    Thanks for all the advice... especially about the no chains up front.. saved me some doe and wasted time.. I went back and looked through the Manuel... had no idea.. I'm mainly buying them to get me through certain check points in big bear and Yosemite.. but if I actually need them I want the best I can get...
    https://www.amazon.com/Peerless-0232605-Auto-Trac-Traction-Chain/dp/B003TDIL5G
    These are probably what I'm gonna end up with... thoughts?
  8. Dec 19, 2016 at 7:42 PM
    Midknight
    Western Canada
    2018 TRD Off-Road
    I just got the same. I believe same size as well
  9. Dec 19, 2016 at 7:43 PM
    JoeCOVA
    Joe
    Colorado Springs
    Those should be fine. I personally run glacier chains (similar). CO doesn't have chain laws for POVs so its basically chain or die on some of the passes.
