Chains or Cables for snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DCGirl, Oct 11, 2010.
  1. Oct 11, 2010 at 12:19 AM
    DCGirl
    DCGirl [OP] Well-Known Member
    California
    4x4
    I have a 2011 Double Cab Prerunner and have read about not using chains because of clearance but have also seen some posts that the clearance isn't an issue if properly installed.
    Im looking at Z6 cables
    http://www.scc-chain.com/Traction Pages/Trac_sz6.html
    Is there any other cables I should consider? I live in SoCal but snowboard a lot and go to Mammoth sometimes. I have never had to install chains on my personal vehicles but Highway Patrol does require it at times, the times I didn't have to do it was because I had a 4x4 which I no longer have.
  2. Oct 11, 2010 at 12:32 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    i hope whatever you get you dont throw them on the front wheels only...
  3. Oct 11, 2010 at 12:39 AM
    DCGirl
    California
    4x4
    I was planning on getting two sets for all four wheels and if its very light snow and required to chain up by highway patrol I would probably just put on the rears instead of all wheels.
  4. Oct 11, 2010 at 12:41 AM
    Manwithoutaplan
    ID
    SHould have gotten a 4x4 :anonymous:
  5. Oct 11, 2010 at 12:52 AM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
  6. Oct 11, 2010 at 1:01 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I've never heard of clearance issues with chains when using them on Tacomas.
    I use cables and they work great, they are cheaper, but aren't as durable as chains. But would be good if you're only using them once and a while.
    I don't know much about the different companies, I purchased mine at Wal-Mart.
  7. Oct 11, 2010 at 7:41 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    If you have a 2 Wheel drive truck putting chains or cables on the front aren't going to help much. I'd just get a set for the rear wheels. We get snow up here once or twice a year that is deep enough to require traction devices and cables seem to work fine. With a truck you can just go to Home Depot and get some sand bags and throw them in the bed right over the axle and that will help a lot.
  8. Oct 11, 2010 at 7:57 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x2. :p
  9. Oct 11, 2010 at 11:46 AM
    DCGirl
    California
    4x4
    Sounds like I should stick to the 1 set and I am considering doing the sandbags. The 2wd Tacoma definitely feels different from the 4x4 truck I use to have. I may be driving with sandbags most of the winter.
  10. Oct 11, 2010 at 11:51 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    You can cut those bags open and use the sand for traction too!
  11. Oct 11, 2010 at 12:57 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    If you go with chains, get low profile ones. The wheel well liner and mudflaps are closer to the tires than you might believe. Ask me how I know.
    It only becomes a problem when you have some snow/ice build-up inside the wheel well, which often was the case for me during a wet snow.
  12. Oct 11, 2010 at 1:04 PM
    Pickett
    Pickett Member
    Maine
    06 Ink
    I have the same truck but an 06. Bought the 2wd in the south before moving to Maine. All you need are some good AT tires, and a couple of hundred pounds of sand in the back and you're golden
  13. Oct 11, 2010 at 2:30 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR
    x3 :D
  14. Oct 11, 2010 at 2:33 PM
    DCGirl
    California
    4x4
    The sandbags I can definitely do, the tires im not so sure. Since I would have to drop close to $800 for the tires. Unless I can sell the stock tires.... I hear the stock tires are crap though. I'll have to find some empty lots when it starts snowing and practice driving with the stock tires. If it scares the hell out of me then I have no choice but to buy the AT's. I use to drive 18-wheelers and 10 speed trucks with tanks that had the near indestructible tires, I remember how important tires are but with the big down payment I just put down on the truck I don't think I should buy tires for another 3-4 months.
  15. Oct 11, 2010 at 2:35 PM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    had to do that once up near lake tahoe lol
    as far as cables...i bought a brand new set and had to take them back 2 days later...they broke after i drove 5 miles! had to buy some from the chain guys along the highway and pay out the a$$.
  16. Oct 11, 2010 at 2:36 PM
    scottri
    Scott
    Tigard Oregon
    Some cable chains in the rear and sand in the bed and you will be good. I've driven in 2 feet of snow with a 2 wheel drive truck with no problems. Take it easy on the gas, no big steering adjustments, give yourself a lot of room for braking and don't hammer the brakes and you will be good.
  17. Oct 11, 2010 at 2:37 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The fact that they are new should help get you through the first year or so with the added weight.
    Not to pile on, but having had a 4 wheel drive in the past, i'm surprised you didn't go that route again. Not real familiar with DC weather though, or how it is affected by all of the hot air that comes out of that area.
  18. Oct 11, 2010 at 3:18 PM
    DCGirl
    California
    4x4
    woah...they broke!? that sucks...what brand were they? crap maybe I should get the chains instead, I just have to be careful with the snow/ice buidling up, I have had that happen when I lived in colorado and driving through utah
  19. Oct 11, 2010 at 3:28 PM
    DCGirl
    California
    4x4
    Yeah I know, i wanted the 4x4 but I live in SoCal, the only time I see snow is when I go snowboarding, that happens about once a week when the season starts. I read that the LSD works better on the 09+ Tacoma's unless I completely misread it so I thought maybe it won't be too bad.Especially after reading some people had Prerunners in areas where they get real snow. More MPGs, less maintenance costs for me. Although the RWD is pretty different from the 4x4 I had and the FWD cars, has a nice turning radius though :D
  20. Oct 11, 2010 at 3:29 PM
    DCGirl
    California
    4x4
    What brand cables chains did you use?
