Chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iflyils, Apr 3, 2014.
  1. Apr 3, 2014 at 7:41 PM
    iflyils
    iflyils [OP] Well-Known Member
    chris
    Wa
    TRD OFFROAD
    HARROP FRONT ELOCKER, ARB BULL BAR, OLDMAN EMU SUSPENSION ARB INTENSITY OFFROAD LIGHTS, WARN 9.5XPS, 32 in BFG MUD TERRAIN KM2, ARE Overland canopy with ARB ROOF RACK Line X premium bedliner
    So can I not run chains on the front? what my alternative?
  2. Apr 3, 2014 at 7:45 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uh, chains on the back? I guess I don't understand the question.
  3. Apr 3, 2014 at 7:46 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you want to run them on all four - the limiting factor is the space between the tire and the upper control arm - and that's determined by which wheels and tires you mounted.
    Once you're on lifted suspension and aftermarket tires, wheels, UCAs, the ruler is going to be the determining factor on whether you can run chains on the front, not the owner's manual.
  4. Apr 3, 2014 at 7:54 PM
    iflyils
    chris
    Wa
    TRD OFFROAD
    yes I would like to be able to run chains on all 4
  5. Apr 3, 2014 at 7:55 PM
    iflyils
    chris
    Wa
    TRD OFFROAD
    ok well I will order a set and see how they fit on the front it is lifted with 265/75/16
  6. Apr 3, 2014 at 8:42 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    factory wheels? or aftermarket?
  7. Apr 3, 2014 at 9:25 PM
    iflyils
    chris
    Wa
    TRD OFFROAD
    factory
  8. Apr 3, 2014 at 11:53 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    No. Also keep in mind that 25MPH is about the limit you want to drive with chains.
    The best thing you can do is get some good snow and ice tires. Take a look at this video.
    http://www.youtube.com/watch?v=qWwK7kx7V44
  9. Apr 4, 2014 at 4:12 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    It could probably be done with 235/85R16 tires, wheels that have 4" backspacing, and with some 1.5" wheel spacers. That would get the inside sidewall of the front tires far enough from the upper control arm so that the chains would be less likely to beat them to death.
  10. Apr 4, 2014 at 7:38 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Some people use wheel spacers to get enough clearance for the front. I think my brother-in-law bought 1" or 1 1/2" spacers and put them on all four wheels He's running stock wheels and tires.
  11. Apr 4, 2014 at 8:35 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I thought it was even noted in the owners manual to not put chains on the front due to potential damage.
    What about cables on the front?
