chainsaw experts? bar oiling.
Discussion in 'Garage / Workshop' started by aficianado, Feb 17, 2013.
  1. Feb 17, 2013 at 5:53 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i have an Echo chainsaw. the thing is pretty powerful. it cuts like a rabid beaver.
    but it seems to leak more oil from below the bar, than what appears to actually make it onto the bar. i tinkered with the adjustment screw and turned it down. i can get the tiniest oil spray slinging from the chain onto a clean piece of wood..so the chain and bar is getting some oil. but what gushes out the bottom is amazing. just a quick rev to sling oil onto the clean wood will leave the bottom of the saw dripping. it is clearly squeezing out between the bar, and the body of the chainsaw. i have the bar clamped down pretty tight to the body with the two nuts. i wiped everything down. the mating surface between the body (i know which is the oiler hole) and the bar is super clean. nothing is wedging them apart.
    is this normal? the only thing i can think of is: at my bowrange i was using my saw to clear the 80 yard target. the range master, without asking, just grabbed my saw from me and attacked a tree. he clearly was not a great tree cutter, because he seized the saw into the tree and we had to "rescue" it with a range saw (craftman). when i got the saw back the chain did not move smoothly. he tweeked the chain, and i had to toss it. maybe he bent the bar a bit?
    i think the Craftman saw they have at the range are woefully inadequate..and dangerous. i'd rather use my own saw, that i am familiar with.
    any tips? try a new bar? help me you wood burning friends!! i'm just a weekend chainsawer..doing yardwork. not my expertise.
  2. Feb 17, 2013 at 6:10 PM
    r0b2008
    r0b2008 Member
    Gaithersburg MD
    08 duble cab
    if you have a air compressor run your blow gun from the sprocket down to the end on both sides of your bar, or use a small flat screw driver there maybe some chud in the bar.
  3. Feb 17, 2013 at 6:15 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2012 TRD double cab
    ARE topper LED light bar Spidertrax
    I did this with a chainsaw. I guess you don't want my help now huh?
  4. Feb 17, 2013 at 6:15 PM
    aficianado
    back to bone stock.
    yea..i did that..i made a brush with a piece of bicycle brake cable. my bar groove is spotless. i followed up with a blast of air from the compressor.
  5. Feb 17, 2013 at 6:15 PM
    aficianado
    back to bone stock.
    tom!!! egads!
    dont make me show you my table saw thumb!! :)
  6. Feb 17, 2013 at 6:17 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    I have a "table saw arm". Kickbacks are not fun, I guess you know that.
  7. Feb 17, 2013 at 6:31 PM
    cdthiker
    cdthiker Well-Known Member
    Tim
    WAY north Idaho
    2012 Tacoma RC 4X4 5speed
    well....
    Not to be that guy ....
    it could be the Saw, Echo is home owner grade, not really know for their ... amazingness
    the are really designed for being used several times a year after storm clean up and such
    there is a really good chance that it is just the quality of the saw....
    has it always been doing this? or only recently?
    the bar oiler is a classic ex of where some brands cut the edges to try and save some money.
    here is some food for thought,
    there are some out there that have no problems useing veggi oil vs bar oil, does the same thing, I personally use Sthil oil for my saw.... but I am a snow, the point I am trying to make is that even if it is leaking oil you can use other products
    also, for the cost of what it might cost you to take it to a shop you can be most of the way towards a solid shil or husky saw
    good luck
