Chalk test/PSI setting question
Discussion in 'Wheels & Tires' started by CoAlpha, Jul 3, 2021.
  1. Jul 3, 2021 at 7:59 AM
    CoAlpha
    CoAlpha [OP] Well-Known Member
    Hi, So I do the chalk test/setting in my garage at my apartment building. Its always 75 degrees (fall/spring weather). The correct PSI is 31 when the wheels are cold. My question is should I pull about 2 psi out and bring the resting "cold" psi dow to 29? I ask because when I drive it goes up about 2/3 psi when the tires get warmed up. And on a side question should I add about 2 psi in the winter when the average temp drops about 30 degrees? I have heard some people say just do the test and leave it all year, I understand thats a good rule for most people. I however have a little OCD and wouldn't mind getting this dialed in. I assume what I want it to have my tires running "hot" or while I'm out driving at 31 PSI correct? And thats what I should really be going after? Thanks for the input!
  2. Jul 3, 2021 at 1:22 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You’re over thinking it. You’re good to go.
    TacoJoeBro and joeyv141 like this.
  3. Jul 4, 2021 at 8:07 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Always adjust your pressure when the tires are COLD. This applies year round, summer, fall, spring or winter. Ignore the "hot tire" pressure.
    Set it at 29 or 30 or 31.
    Chances are you pressure gauge can't tell the difference between the 3 pressures. The gauge resolution and accuracy aren't that good.
  4. Jul 4, 2021 at 8:12 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    2psi isn’t worth worrying about at all
    unless you’re running drag slicks
  5. Jul 4, 2021 at 8:23 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Fill the tires with nitrogen :anonymous:
  6. Jul 5, 2021 at 6:33 AM
    Knute
    I use an 80% mix of N2 and other stuff. Works perfectly for non-race rides. Plus it is less expensive than N2
    po35042 and davidstacoma like this.
  7. Jul 10, 2021 at 2:10 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’ve had some experience with this and have found the following mixture of gases performs quite well for tires:
    Nitrogen — 78 percent
    Oxygen — 21 percent
    Argon — ~1 percent
    po35042, JustJon and TacoJoeBro like this.
  8. Jul 10, 2021 at 2:32 PM
    rnish
    Tacoma 2nd gen
    I like a trace of Helium; lightens the over all tire weight.
    davidstacoma[QUOTED] likes this.
  9. Jul 10, 2021 at 2:37 PM
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    I think you are on to something here..
  10. Jul 10, 2021 at 2:42 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    lol I’ll give it a try
    davidstacoma likes this.
  11. Jul 10, 2021 at 2:57 PM
    davidstacoma
    David
    NC
    Hydrogens the lightest, going 100% hydrogen in your tires is known as the Hindenburg fill.
