Challenging squeaking noise from rear wheel area
Discussion in 'Technical Chat' started by Tbryson2, Oct 2, 2019.
  1. Oct 2, 2019 at 5:16 PM
    Tbryson2
    Tbryson2 [OP] Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    I have a 2005 Tacoma dual cab. About 6 weeks ago I noticed an odd squeaking noise from the rear. I originally thought it was tire friction on a new paved parking lot. It was only recently that I determined it was squeaking when in reverse (only) and only when in gear. If I coast backwards, it is silent. No noise ever when in forward gear.
    The noise sounds like when you rub a balloon. Not a metallic squeak.
    IF I isolated it correctly, it emanates from the rear passenger side only. I pulled the drum off, and saw nothing out of the ordinary.
    I towed a travel trailer about 1500 miles and it is no worse.
    Anyone out there have a clue? I don’t suspect bearings because it only happens when in reverse gear. No other times
    TB2
