Champion makes aluminum radiator for 3rd gen 4runners?
Discussion in '1st Gen. Tacomas (1995-2004)' started by COMAtized99, Mar 17, 2017.
  1. Mar 17, 2017 at 8:14 PM
    COMAtized99
    COMAtized99 [OP] Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    So, I've been looking for a aluminum radiator for my Tacoma. It looks like NOBODY makes an all aluminum radiator for our trucks.
    However, champion makes one for the 96-02 4runners. I did a quick check on Rock Auto and from what I can see, the 4runners and Tacoma might use a different radiator?
    Anyone have any first hand knowledge on the difference ?
    http://www.championradiators.com/product/CC1998
  2. Mar 17, 2017 at 8:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Mar 17, 2017 at 9:03 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It would be really nice if Koyo Rad would make one. They still do for the early trucks
  4. Mar 17, 2017 at 10:35 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    hmm.... this is something i may have to look into.... Granted the 3.4l doesnt really have much of an issue in the cooling department..
  5. Mar 18, 2017 at 12:17 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Can't you buy one for the earlier models and fab up some mounting brackets? Assuming it's got the typical trans fluid inlet/outlet at the bottom.
  6. Mar 18, 2017 at 1:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I made brackets and installed a Copper Brass Radiator in my 2000 out of a mid 90`s 3.0
    I can`t see that you could not do something along those lines.
    I had to get creative with the bottom hose but nothing major
  7. Mar 18, 2017 at 4:34 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    I'm really just wondering what the difference is between the 4runner and Tacoma radiator. If it is just mounts, I can deal with it.
  8. Mar 19, 2017 at 4:22 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have the same Radiator in my 92 4Runner and my 2000 Tacoma
    Also in my 87 4Runner 22Re
    Just making brackets to fit and getting creative with the lower radiator hose.
    You do need to start with a radiator that is close in size to what is in your vehicle now
    Making sure the top outlet is on the right and bottom on lower left
    Outlets cab be moved but it tends to be a pain
    ** Directions are from sitting in the drivers seat as the should be.
  9. Mar 19, 2017 at 9:45 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    I'm looking for factory size radiator that will fit in my Tacoma and cool my v8 in any situation.
    The one I have now is not big enough. The tundra radiator is too wide to fit between the frame rails. However, according to the specs on the champion site, the radiator they make for the 4runner is nearly the same size, but a bit narrower to clear the frame. Unfortunately, the inlet/outlet are on the wrong side. However, I know a good welder, and as long as the transmission cooler is not in the way, I feel like I could have them swapped.
