Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Feb 24, 2019 at 1:48 PM
    #341
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    keep an eye on your coolant levels.
  2. Feb 24, 2019 at 7:47 PM
    #342
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Completed install today!
    Thanks to @Adude , @BlackPearl , @Blackdawg , @Digiratus !!!
    Some pointers to share:
    remove the grill - to access the 4 bolts that hold the radiator to the core support.
    use 3/8" or 1/2" bolts to stuff into the trans cooler lines to reduce leakage.
    have hose clamps ready in case the OEM clamps won't cooperate.
    fill engine side first from top coolant hose.
    fill overflow tank.
    get burping kit.
    test fit the lower shroud before mounting the upper shroud.
    trim the shroud to fit the transmission cooler lines bigger than you think.
    As Monte stated, the nutserts are questionable. If you have time and ability, change them in advance.
    Corner marker lights - casualty of install - both sides - broken top tabs just looking at them...
  3. Feb 25, 2019 at 10:00 PM
    #343
    pullingin
    pullingin Well-Known Member
    Unfortunately I have decided to return the Champion and replace it with an OEM at $240. After reading some of the experiences members have had it started to make me ill looking at it in the garage. I do not want to worry about it failing. The OEM will go at least 100k.
    I wish this beautiful radiator didn't have the issues reported in this thread.
    I wish everybody who has one installed a super long life! ...and please keep us posted.
  4. Mar 5, 2019 at 8:06 PM
    #344
    pullingin
    Just found out the OEM radiator for a 98 3.4 4x4 manual is discontinued... Anyone know where I could get an authentic OEM replacement?
    I have read some say the Denso was the OEM manufacturer but the reviews of the Denso could be better.
  5. Mar 5, 2019 at 8:20 PM
    #345
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    There's no shortage of aftermarket radiators at 100-125, at that price they are disposable if they last you three or four years,
    The plastic parts are what failed for me
  6. Mar 5, 2019 at 8:24 PM
    #346
    Blackdawg
    Monte
    Wyoming/St. Louis
    So I got an RMA for mine. Hopefully I'll get it replaced whenever they are back in stock
    xtremewlr likes this.
  7. Mar 5, 2019 at 9:24 PM
    #347
    Phessor
    Phessor Well-Known Member
    I received one as well, mailed it off last week. Was told they are on back order till???
  8. Mar 5, 2019 at 10:31 PM
    #348
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah no idea how long it will be..
  9. Mar 5, 2019 at 10:59 PM
    #349
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    So your out of a radiator until they have more in stock with no ETA. Now what, either buy a replacement or have your truck out of commission? Hopefully you kept your old one. Good luck to everyone. Keep a spare just in case ;)
  10. Mar 5, 2019 at 11:13 PM
    #350
    Phessor
    I kept my old one and that is what I am currently using.
  11. Mar 5, 2019 at 11:19 PM
    #351
    Blackdawg
    Monte
    Wyoming/St. Louis
    Same back on the original
  12. Mar 6, 2019 at 9:58 AM
    #352
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I’ve had this radiator on backorder since the end of January. Called Champion today, they said they won’t arrive in the states until the end of this month.
    Might cancel this shit with the long as fuck backorder, lack of communication, and failures.
  13. Mar 20, 2019 at 5:51 AM
    #353
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I installed mine recently, the nutserts were just fine. Same type I used in my bed to install the rack. -shrug-
  14. Mar 20, 2019 at 5:52 AM
    #354
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I rolled the dice with this. Worse comes to it, I am keeping a spare at the auto parts store. It'll cost me a couple bucks to get it, but I don't think I will need it anytime in the next few years.
  15. Mar 26, 2019 at 6:43 PM
    #355
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    So just ordered this thing from eBay, will post up what it looks like when I get it. Also is the only place to buy the gates 22120 is from O'reillys or Walmart? Just curious. Going to flush the entire system because it's never been done since I've owned the truck
  16. Mar 26, 2019 at 7:17 PM
    #356
    tony2018
    tony2018 Well-Known Member
    won't arrive in the states? fuck that...
  17. Mar 26, 2019 at 9:58 PM
    #357
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Amazon, super low pricing...
    BYJOSHCOOK[QUOTED] likes this.
  18. Mar 28, 2019 at 11:23 AM
    #358
    Phessor
    Look what showed up on my doorstep.
  19. Mar 28, 2019 at 11:27 AM
    #359
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They aren't robo welded, they're welded by hand in the same Chinese factory that does all the other aluminum radiators that are under $300 haha. I've bought Champions before and within the last couple years they must've upped volume or something. Last one looked like Ray Charles welded it with his feet.
  20. Mar 28, 2019 at 11:35 AM
    #360
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Mine should be here by the 1st! Hopefully it isn't an April Fools joke :(
    Phessor[QUOTED] likes this.
