Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Apr 8, 2019 at 7:22 AM
    #401
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    So I replaced my radiator this weekend and so far it's working fine (didn't drive it much as I was quite busy with other things) but I noticed the petcock valve is weeping coolant. Even after I took it out and put a good amount of Teflon tape on it. So question is should I drain it again and add even more tape than last time or should I use some type of radiator epoxy or something similar to stop it.
  2. Apr 8, 2019 at 7:25 AM
    #402
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    I actually put a LOT of tape when I installed mine 30k ago, no issues since then
  3. Apr 8, 2019 at 7:38 AM
    #403
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Mine was too. I finally figured out that you have to turn the outer part with the ears out, like you’re unscrewing it. It feels like there’s some rubber in there so I was careful to not put too much force in it. When it stopped weeping I left it alone.
    1997tacomav6[OP] likes this.
  4. Apr 8, 2019 at 7:44 AM
    #404
    Shortman5
    Supercharged TRD
    My issue is that I installed what I thought was a 170 degree stant a year ago. It didnt do much and I was told over and over that only a better radiator will help lower temps. Well nothing has changed. I’m thinking I got a 180 in a 170 box on the thermostat.
    So here we go again, making a mess and having to fuck with it all over again to change the thermostat again. This time I have a OEM Toyota 170 degree Camry thermostat. Gotta go back in anyway because USPS fucked me when I paid for expedited shipping on belts to be delivered Sunday. Some dipshit marked it delivered to the mailbox but I never got them.
  5. Apr 8, 2019 at 7:48 AM
    #405
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Then I'll try and drain it one of these nights and add a bunch more tape and hope it fixes it.
    I'm not leaking from the valve it self but the nut that it's attached to so I guess just a bunch more Teflon and it will hopefully work :fingerscrossed:
  6. Apr 8, 2019 at 7:53 AM
    #406
    1997tacomav6
    Denver
    Pull the whole petcock out if needed to see what going on, put a lot of tape on should do it. That tape is so
    thin it takes a lot if you have a larger gap
  7. Apr 8, 2019 at 8:10 AM
    #407
    Shortman5
    Supercharged TRD
    Could try pipe dope as well. Won’t degrade over time, it stays tacky, and I believe is more resistant to temperatures.
    burntkat likes this.
  8. Apr 8, 2019 at 9:07 AM
    #408
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Going to do both so I don't have to deal with it again haha
  9. Apr 8, 2019 at 10:55 AM
    #409
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Ebay
    New Fan Shroud for Toyota Tacoma 1996-2000
    TO3110111 1671107020 723650024621
    $33
    Courtesy of @BlackPearl
  10. Apr 8, 2019 at 12:03 PM
    #410
    Shortman5
    Supercharged TRD
    Yeah, out of stock everywhere. But damn that’s a much better price than what I just paid for. Got one from Amazon and I’m going to have to cut it up.
  11. Apr 8, 2019 at 4:17 PM
    #411
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Don't see the need for a 170 stat unless you're running a blower. Motor was designed to run at 185
  12. Apr 8, 2019 at 4:21 PM
    #412
    Shortman5
    Supercharged TRD
    That’s why I want to run the 170.
    burntkat and Blackdawg[QUOTED] like this.
  13. Apr 8, 2019 at 4:36 PM
    #413
    1997tacomav6
    Denver
    I have the 185 stat with supercharger and the engine never runs at 185.
    It runs at 188-190
  14. Apr 8, 2019 at 4:51 PM
    #414
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's fine. Under 200 is great. Lower that 180 isn't really good
  15. Apr 8, 2019 at 4:54 PM
    #415
    Shortman5
    Supercharged TRD
    Mine runs at 190-196. Exactly like it did before.
    I’d like it to run ~185
  16. Apr 8, 2019 at 5:01 PM
    #416
    1997tacomav6
    Denver
    Getting a 170 stat I don’t think will change your numbers, but try and let me know
    burntkat and Speedytech7 like this.
  17. Apr 8, 2019 at 5:21 PM
    #417
    Shortman5
    Supercharged TRD
    This is always a debated subject. I’ve been told that before. Magnuson includes a 170 in the 4.0 kit. I don’t know why a company like magnuson would do that if it didn’t do anything at all.
    You may be correct. It’s possible my system is rusted on the inside not allowing the water to take the heat with it.
    It’s also possible I do in fact have a 170 stat and it allows the water to move too fast and won’t take the heat with it.
    Or maybe it’s just the fact you like in a high altitude dry climate and I’m in a sea level humid climate.
  18. Apr 8, 2019 at 5:30 PM
    #418
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.0 is a totally different motor and different blower. It's a sleeved block so keeping temps down is more important. And it uses an air to water intercooler. Separate from the coolant obviously but can't really compare that to our motor.
    Long as it's under 205 it's fine. You're under 200 so I wouldn't expect much of a change.
  19. Apr 16, 2019 at 9:24 AM
    #419
    BYJOSHCOOK
    Josh
    Check Out My Builds
    So I got my leak to stop and it runs fine (other than AC clutch going bad) and I'm still getting the same temps 194-203. Little disappointed that nothing changed but since my original radiator shit the bed it's not as bad
  20. Apr 16, 2019 at 9:44 AM
    #420
    Shortman5
    Supercharged TRD
    Yep. Mine didn’t change much either. I really think the stock radiator could cool just fine and the thermostat does make a difference despite what people say. Just using a OEM thermostat with the juggle turned to 6 gives people about 8 degrees lower temps on a stock radiator. For me, using a cheap parts store stat without a jiggle valve gave me a drop of 5 degrees or so even before the new radiator.
    For my case I really think it’s the thermostat that sucks. It will work it’s way up to 199 then drop to 190 and sometimes lower then do it over and over.
    I have a 180 and 170 superstat waiting to install. When I get a chance I’ll install one and report back. Just haven’t decided which one to try yet.
    BYJOSHCOOK[QUOTED] likes this.
