Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Apr 16, 2019 at 9:57 AM
    #421
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'm going to replace the thermostat when I do the timing belt and WP replacement next year. Really wish I could've waited to do the radiator swap then to but with my luck nothing works out the way I plan.
    Yetimetchkangmi likes this.
  2. Apr 16, 2019 at 10:15 AM
    #422
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    Thats a sexy looking radiator.lol
  3. Apr 16, 2019 at 10:44 PM
    #423
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Guessing your jiggle valve isn't pointed at 6
    Luv my yota likes this.
  4. Apr 16, 2019 at 11:01 PM
    #424
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Did a 22re champ rad swap still in a 3.4 though lol
  5. Apr 17, 2019 at 6:38 AM
    #425
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Probably not but I may swap a new thermostat in if I need to do other work here soon
  6. Apr 17, 2019 at 6:45 AM
    #426
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    If it’s running 205 you have some other issues going on.
    Maybe a fan clutch?
    AC condenser plugged up blocking airflow to the radiator ?
    The plastic fan blades warped?
    Did you burp the system correctly? With heater valve open?
    With the burping radiator filler kit?
    Any air in the system will run hotter
    My truck NEVER gets over 200 degrees, 191 degrees is its max normally and if I’m at idle on a hot day and it gets a bit warm I can rev the rpms up to 3k and the temp drops down to 188 in 30 seconds literally
    burntkat and Luv my yota like this.
  7. Apr 17, 2019 at 7:00 AM
    #427
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hmm no idea, I guess I could look into the fan clutch. But I'm also going to replace my thermostat next time I pull my radiator (need to fix my AC clutch and it'll give me more room) so like Monte was saying it could be in the wrong position :notsure:
  8. Apr 17, 2019 at 7:10 AM
    #428
    1997tacomav6
    Denver
    Wrong position will definitely!!! add 5-10 degrees I know for a fact because I installed my incorrectly at first and ran at 200-205 degrees
  9. Apr 17, 2019 at 7:18 AM
    #429
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's why I'm thinking the PO whenever they did the timing belt and WP they put it in the wrong position so in the next month or so (unless it get's worse) I'll roll with it until I fix the other stuff. The truck also isn't my only daily
  10. May 8, 2019 at 9:29 AM
    #430
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Hey bud, when you put the connectors on for the AT section did you use pipe dope or tape? Or just put them on by them selves because they have a flare on the end of the pipe.
  11. May 8, 2019 at 9:31 AM
    #431
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Which shroud is this one? I had to cut an 1 1/2 inches off the bottom of mine.
  12. May 8, 2019 at 2:30 PM
    #432
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Been doing a lot with my truck lately but this is something I’m really happy getting done. I did get a better cap for the radiator it’s just not in the pics.
  13. May 8, 2019 at 2:33 PM
    #433
    RedManRocket
    Red
    2002 Double Cab LT
    Curious, what's wrong with the cap it comes with
  14. May 8, 2019 at 2:36 PM
    #434
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    If you read through this thread people had pressure issues and recomended to get a better quailty one.
  15. May 8, 2019 at 2:38 PM
    #435
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    You should be able to use your oem one if its still in good working order or get a new oem cap.
    burntkat likes this.
  16. May 8, 2019 at 2:40 PM
    #436
    RedManRocket
    Red
    2002 Double Cab LT
    Ooo, I see. As in, it lets it get too hot or not enough?
  17. May 8, 2019 at 2:46 PM
    #437
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Look at this quoteVVVV
  18. May 8, 2019 at 2:48 PM
    #438
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Not really, my cap was to small for the champion radiator.
  19. May 8, 2019 at 4:23 PM
    #439
    pullingin
    pullingin Well-Known Member
    How has the longevity of this radiator been y'all?
  20. May 8, 2019 at 4:31 PM
    #440
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Few months in. Hasn’t exploded yet.
