Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. May 8, 2019 at 4:40 PM
    #441
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Noted, I'll get a different one. Thanks Ray :thumbsup:
    SilverGhost[QUOTED] likes this.
  2. May 8, 2019 at 5:04 PM
    #442
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    It’s actually not the pressure, it’s the metal locking tabs that are junk and bend, then it leaks because the locking tabs don’t lock the cap to the radiator
  3. May 8, 2019 at 5:47 PM
    #443
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Strange. Mine and others on here were able to use our oem replacement cap.
    burntkat likes this.
  4. May 8, 2019 at 5:52 PM
    #444
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I have the updated version. Should I get a different cap? Using the one that came with the radiator right now.
  5. May 8, 2019 at 6:00 PM
    #445
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    I used my oem replacement cap from my old radiator. It worked better.
  6. May 8, 2019 at 6:22 PM
    #446
    1997tacomav6
    Denver
    The newer version radiator I believe uses the stock radiator cap
  7. May 8, 2019 at 6:36 PM
    #447
    Shortman5
    Supercharged TRD
    Stock size but it came with a Champion cap which I’m using. Don’t think it’s a Toyota cap.
  8. May 8, 2019 at 7:16 PM
    #448
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Manual V6 4x4 :notsure:
    Holds 2lbs less pressure :oops:
  9. May 8, 2019 at 7:23 PM
    #449
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I'll check one out on rock auto, thanks bud.
  10. May 8, 2019 at 7:25 PM
    #450
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Just caught this. I've been running an auto zone radiator.
  11. May 13, 2019 at 8:41 AM
    #451
    TheMonkey
    TheMonkey New Member
    Hey John - sounds like 188 is where your thermostat equilibriates. Exact same as mine. Is this idle condition the only time you see it go over that? What if you don’t rev, where do you see it go?
    Pulling grades go over 188?
  12. May 13, 2019 at 2:22 PM
    #452
    1997tacomav6
    Denver
    It seems to bounce around from 188-190,
    At idle ( no,rev) sometimes to 193.
  13. May 14, 2019 at 11:17 AM
    #453
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    How are you measuring that?
    Scanguage?
  14. May 14, 2019 at 12:28 PM
    #454
    1997tacomav6
    Denver
  15. May 15, 2019 at 4:29 AM
    #455
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Wasted effort. The nutserts work just fine. Maybe add thread lock?
  16. May 15, 2019 at 4:31 AM
    #456
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Take the new radiator to two store. Size up before you begin. Seriously?
  17. May 15, 2019 at 4:32 AM
    #457
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Not using them
    cruiserguy and 1997tacomav6[OP] like this.
  18. May 15, 2019 at 4:36 AM
    #458
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Why not run the thermostat that is actually designed for this application? 180 is what is supposed to be there. The ecu won't even go into closed loop mode till just under 180. These things are designed this way for a reason. Namely, to make sure everything is seated properly and operating in the designed tolerances.
  19. May 15, 2019 at 4:39 AM
    #459
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Treat the cooling system with RMI-25. That will make things clean, and work optimally
  20. May 15, 2019 at 4:44 AM
    #460
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Put them on dry. IIRC, they are JIC fittings, and designed to be used dry. At any rate, 'flare' means it's to be used dry.
