Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. May 15, 2019 at 4:45 AM
    #461
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Or just, you know, use the one that came off the old radiator. Worked fine.
    (EDIT: seems there was a design change. Unless you buy the old style, which I don't know how you'd get at this point, just use the stock bit).
    SilverGhost[QUOTED] likes this.
  2. May 15, 2019 at 7:22 PM
    #462
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    That's what I did. Thanks.
    burntkat[QUOTED] likes this.
  3. May 16, 2019 at 8:26 AM
    #463
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    This is correct. Do not over tighten either. One of the downsides to JIC is if overtightened it can ruin it and won’t completely seal.
    SilverGhost and burntkat[QUOTED] like this.
  4. May 16, 2019 at 12:08 PM
    #464
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    True, but they are MUCH harder to distort than their Aluminum counterparts, AN fittings.
    SilverGhost likes this.
  5. May 30, 2019 at 3:45 PM
    #465
    pullingin
    pullingin Well-Known Member
    Anyone have any updates on the longevity of this radiator?
    Would like to know how it is working for you.
  6. May 30, 2019 at 3:54 PM
    #466
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    I installed mine a little over a year ago and around 30,000 miles on the radiator.
    No issues here, works fantastic
    Some people have had a few leaks if you read through the thread you will see
    Dalandser likes this.
  7. May 31, 2019 at 8:02 AM
    #467
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I think I installed mine about 3 months ago. No leaks, no overheats, no worries. It just works.
    1997tacomav6[OP] likes this.
  8. Jun 1, 2019 at 12:52 AM
    #468
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    so..
    there is a function on the form call Multi-Quote. Instead of quoting and posting one at a time, if you click the Multi-Quote + thats just to the left of Quote, it'll just save who you want to quote. Even if you go to the next page.
    Then at the bottom in the reply section, you just click Insert Quote and you can then pick which ones you want to keep. It'll insert them in order, then you can reply to them all at once in one post.
    Just a tip..
    Yetimetchkangmi likes this.
  9. Jun 3, 2019 at 10:56 AM
    #469
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yeah, I saw this last time you posted it. I'm quite well aware of it.
    I just don't care.
    It's not going to happen on a 5" screen.
    RonJon31, cruiserguy and Sreppep like this.
  10. Jun 3, 2019 at 12:33 PM
    #470
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol it's just as easy on a phone man. But whatever
  11. Jun 3, 2019 at 4:13 PM
    #471
    Phessor
    Phessor Well-Known Member
    I was reluctant to install the replacement radiator and for good reasons. I took the day off today so that I could swap out my old WORKING radiator for the replacement Champion radiator. I finished up the install and had me truck running to warm it up and what does my ten-year-old daughter tell me, “Dad, your truck is leaking.” Sure enough, right in the middle of the lower tank weld is a nice steady drip!
    Now I have wasted two days of work replacing BAD Champion radiators for old original working radiator. So, I am out the $213.37 for the original BAD Champion radiator, thirty something dollars to mail back the BAD Champion radiator, two days off work, and now another thirty something dollars to ship another BAD Champion radiator back.
    What is going on with the quality control section at Champion radiator? Do they even check them? Or do they just expect them all to work correctly? All I know is that I am very upset with this whole fiasco and I want my money back! I should have asked for my money back in the first place, at least I wouldn’t be out more money and wasted time.
    (Edited, the lower price was for another Toyota radiator that ebay tried to sell me.)
    cruiserguy and US Marine like this.
  12. Jun 3, 2019 at 4:18 PM
    #472
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    where do you see $134 :anonymous:
    eimkeith likes this.
  13. Jun 3, 2019 at 4:19 PM
    #473
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    right? I'll re-weld it for that price. where is it?
    burntkat and 1997tacomav6[OP] like this.
  14. Jun 3, 2019 at 6:15 PM
    #474
    Phessor
    See edit above.
    See edit above.
    foxrcing07[QUOTED] likes this.
  15. Jun 3, 2019 at 6:46 PM
    #475
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Let’s hope all of us have better luck down the line. I don’t know anything about champion beside their customer service isn’t the best. Everyone raves about this radiator for our 1st gen but they haven’t been out long enough to know their durability.
    I understand your frustration and I think we all been there. It is what it is and we just have to move on. Fortunately for me I got this radiator for free because of their lack of service so I can’t be too upset if it doesn’t hold up. I also have some JB weld on stand by :)
  16. Jun 3, 2019 at 10:38 PM
    #476
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Alumifix™ Welding Rod's This is all you need to fix any holes .
  17. Jun 3, 2019 at 11:00 PM
    #477
    Blackdawg
    Monte
    Wyoming/St. Louis
    Been out long enough with almost a 50% fail rate near as I can tell.
  18. Jun 3, 2019 at 11:23 PM
    #478
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Out of curiosity, @1997tacomav6 you should add a poll to see how many radiators have failed and how many are still up and running with no issues. Maybe something like:
    1.) failed with in 5k miles
    2.) running past 10k
    3.) running past 25k
    4.) running past 50k
    Edit: mine failed around 8k. (Started leaking)
    Yetimetchkangmi and burntkat like this.
  19. Jun 3, 2019 at 11:26 PM
    #479
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I was planning on getting Champion radiator for my Camaro as they had a custom 3 row aluminum radiator capable of supporting 800 plus hp . Then I found out they used small tubes (3/4" tubes) . This would cause the radiator not to cool as efficiently as a 2 row radiator with bigger tubes
    Plus as you mentioned bad quality control with bad welds . I decided on purchasing a very nice Griffin Aluminum 2 row radiator that had 1.25" tubes that supports 800hp
    I know this radiator doesn't fit our Tacoma's but it's very nice and comparable to a BeCool or C&R radiators
  20. Jun 4, 2019 at 5:46 AM
    #480
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I'm guessing you're not in your late 40s, are you? ;)
    It's a vision thing, not a GUI thing..
    TacoJohn4x4 and cruiserguy like this.
