Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Jun 6, 2019 at 4:13 AM
    #501
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    The shroud for the v6 3.4 with manual transmission 4x4 as shown here is what you want.
    burntkat likes this.
  2. Jun 6, 2019 at 4:31 AM
    #502
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    This ^^^^
    2wd 3.4 models work as well.
    I am using Toyota part # 16711-07020 - Cooling system, Cooling Fan shroud, 3.4 LITER 2WD, W/O PreRunner
    (1) Lower shroud - 16712-07010
    (2) Clip - 90468-06092
    burntkat and 1997tacomav6[OP] like this.
  3. Jun 6, 2019 at 6:16 AM
    #503
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Clutch fans are far superior to electrics, unless you lay out serious coin for a custom rig or spend a lot of time trying things that won't work- which is laying out a lot of cash, too. I've been there with the electric vs clutch considerations when putting the smallblock in my S10. I was able to use a Dodge Intrepid fan, but only due to the shape of my radiator being nearly custom-made for it.
    Even at that, the clutch fan works better, it's a simple matter of CFM of air moved. Electric fans have their place- when you have a packaging problem (transversely mounted engine, or not enough space between the radiator and pulley to run a clutch, as in my case)
  4. Jun 6, 2019 at 6:17 AM
    #504
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    No, it's the first gen manual for the 3.4.
    That's literally what is in my truck. I had to cut two holes in the bottom for hose clearance, and it went right in.
  5. Jun 6, 2019 at 6:19 AM
    #505
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    But how many CFM does it move?
    Is that a diesel application? Remember, diesels LIKE to run hotter, so cooling isn't such a concern.
    1997tacomav6[OP] likes this.
  6. Jun 6, 2019 at 6:50 AM
    #506
    1997tacomav6
    Denver
    Keep me updated on this, looks like a nice fit
    eimkeith[QUOTED] likes this.
  7. Jun 6, 2019 at 7:05 AM
    #507
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    A lot?
    https://youtu.be/kGylouOxVL0
    It’s also about the shroud; and this fits REALLY well. Bad shroud = less fan performance.
    souvang likes this.
  8. Jun 6, 2019 at 7:10 AM
    #508
    1997tacomav6
    Denver
    Mmmmm Wow, that looks impressive, another swap to think about now,
    That would definitely be a great fit for those rock crawlers that are at low rpms and hot weather Or stop and go traffic in Nevada
  9. Jun 6, 2019 at 11:00 AM
    #509
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
  10. Jun 6, 2019 at 11:08 AM
    #510
    eon_blue
    Azusa, CA
    I had bad luck with (dual) Flexalite electric fans on my truck, they did not cool the engine well at all especially in 4wd. AC on in 4wd would cause me to overheat almost every time.
    Put a stock fan clutch setup back in and everything was peachy keen again. Can run AC in 4lo on 100˚+ day and won't see temps above normal.
    IMO the e-fans work great on street driven performance applications, but in a slow moving/crawling high temp environment they don't perform as well as the fan clutch. Before I committed to switching back to stock, I read a number of accounts on here of similar experiences.
  11. Jun 6, 2019 at 11:20 AM
    #511
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I ordered the one you linked too, right after you linked it... It appears that it's actually the same shroud as the "3.4l munual" shrouds everyone is talking about. :thumbsup:
  12. Jun 6, 2019 at 11:21 AM
    #512
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I passed on the information that @BlackPearl sent me...
    BlackPearl likes this.
  13. Jun 6, 2019 at 11:30 AM
    #513
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I might be going back to stock:
    In DVNP in May 2019, I was in 4HI, 17psi, RTT and trip gear; Transmission temp light came on (the only fluid I didn't change before the trip), shut off truck on the way out of Saline Valley to Hunter Mt intersection for 15 minutes, had to Gerry-rig a funnel out of a hi-octane booster bottle and filled up 1/2 qt. Good until the next day in Badwater basin area and temp light again, except I was at 45mph so there was plenty of cooling going on. After shutting down for 10 minutes to cool, I limped out in 4Lo to the main road then to Furnace Creek and pulled the plug to head home instead of risk equipment failure.[/QUOTE]
  14. Jun 6, 2019 at 1:36 PM
    #514
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Efans..cool idea...shitty reliability though and WAY too loud compared to the basically unbreakable mechanical fan.
    If you offroad. E fans should never be even a thought.
    cruiserguy, burntkat and Wulf like this.
  15. Jun 6, 2019 at 2:54 PM
    #515
    eimkeith
    J Keith
    we'll see.
    also, in my experience, OEM electric fans are far quieter than mechanical fans. (come to think of it, I've had to replace exactly one electric fan in the 31 years I've owned cars & trucks...)
  16. Jun 6, 2019 at 2:59 PM
    #516
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Not here they aren't...
    eimkeith likes this.
  17. Jun 6, 2019 at 3:22 PM
    #517
    eimkeith
    J Keith
    Isn't that how you break a mechanical fan?
  18. Jun 6, 2019 at 4:15 PM
    #518
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Let the guy use a E fan. It’s a win win. It’s his truck so if anything happens you’ve already warned him. If it happens to work well it’s another upgrade option for us.
    Let us know how the E fan goes :)
    1997tacomav6[OP] and Adude like this.
  19. Jun 6, 2019 at 4:20 PM
    #519
    eimkeith
    J Keith
    will do. :)
  20. Jun 6, 2019 at 5:30 PM
    #520
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Good you got the right one. I was going to say you don't want the 2.7 because the fan opening is in a different location the the 3.4. When I did my engine swap from 2.7 to 3.4 I had to get a new 3.4 shroud.
