Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Dec 8, 2019 at 8:06 AM
    #621
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Ok, thanks for the info!!
    XPOTRPR likes this.
  2. Dec 8, 2019 at 8:16 AM
    #622
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No problem. I got mine for 180 from eBay. For the price, it was worth a shot to me. Definitely worth it imo.
  3. Dec 8, 2019 at 8:39 AM
    #623
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    They are a great radiator if you get one that doesn’t end up leaking.
    Just don’t be surprised if it pops a leak down the road and be prepared for your next step if it does in advance so you have a plan already Because under warranty the replacement might not be available and have to wait 3 months for another shipment till available
    eimkeith likes this.
  4. Dec 8, 2019 at 8:48 AM
    #624
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good to know. So far so good. I'll keep an eye on it now tho. :thumbsup: luckily it's my second vehicle so if it does go, I'll just throw in another one.
    I kind of want to get it pressure tested now though.
  5. Dec 8, 2019 at 8:51 AM
    #625
    1997tacomav6
    Denver
    Mine worked fantastic for 30,000 miles then it popped two leaks for no reason.
    They were back order for warranty replacement for 3 months so had to go a different route.
    Just an FYI
  6. Dec 8, 2019 at 8:57 AM
    #626
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Got ya. Maybe I'll just order another one and have it on hand.
  7. Dec 8, 2019 at 9:13 AM
    #627
    1997tacomav6
    Denver
    Just have a stock 100 backup ready
    burntkat likes this.
  8. Dec 8, 2019 at 9:58 AM
    #628
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    After reading all the replies in this thread I’m thinking it might need to be installed with rubber isolators. The lack of plastic in it may make it too rigid for an off-road truck.
    Any thoughts?
    burntkat and eimkeith like this.
  9. Dec 8, 2019 at 9:58 AM
    #629
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Yup
  10. Dec 8, 2019 at 1:49 PM
    #630
    1997tacomav6
    Denver
    I think because radiator is not super thick aluminum any stress on it from the frame twisting whether you're four-wheel driving May crack the radiator welds,
    I'm pretty sure that's what's happening to these radiators rubber bushing might help a little bit but it would have to have a lot of flex
  11. Dec 8, 2019 at 3:58 PM
    #631
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    I suspect this as well.
  12. Dec 8, 2019 at 9:19 PM
    #632
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Is there a link to rad bushings?
  13. Dec 9, 2019 at 8:03 AM
    #633
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    google.com
    Find the size of the screws that hold the radiator in (EDIT: I think they are M6, but don't quote me). Find rubber bushings that will fit those. I'd go with something around 1/4" thick, then bolt the radiator into the truck with them between radiator and radiator support. (EDIT: buy longer bolts, too)
    That said, I doubt twisting is the problem. Vibration might be.
  14. Dec 11, 2019 at 11:16 AM
    #634
    270Fan
    270Fan Member
    Jack
    Southern California
    2015 Tacoma TRD doublecab
    No. They are trash.
  15. Jan 16, 2020 at 11:10 AM
    #635
    Benfica15
    Benfica15 New Member
    Found this thread after receiving my Champion radiator(98 4Runner) and see a giant sticker saying to use “Only the green stuff” for antifreeze.
    For anyone who has run or is running a champion radiator, did you run Toyota Red or Green? Did champion chalk up the failure to that?
    When I called champion to ask about running Red they said that they had reported failures due to running Red and to switch over to Green and by doing so I save money...Not too happy with them since they are building radiators for Toyota’s and not mentioning anything prior to purchase about not being able to run the coolant our vehicles are spec’d with.
  16. Jan 16, 2020 at 3:47 PM
    #636
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I run red. So far no issues, about 7 months.
  17. Jan 16, 2020 at 4:32 PM
    #637
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That’s too bad this radiator has questionable reliability. I take my truck to remote places to often to risk it.
  18. Jan 17, 2020 at 6:24 AM
    #638
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I didn't have that sticker on mine when I put it in. Never heard that before.
    I run the proper antifreeze- Toyota red, and have no issues.
  19. Feb 6, 2020 at 4:29 AM
    #639
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Well chalk up another failure. I have had mine for about 30k miles and it just started leaking at the bottom. I don't wheel and do a lot of road driving.
    That RED fluid must have sprung the leak.
    1997tacomav6[OP] and otis24 like this.
  20. Feb 6, 2020 at 7:32 AM
    #640
    1997tacomav6
    Denver
    Join the club, mine went out at 30k miles too
