Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Aug 1, 2022 at 10:05 AM
    #761
    firemaniac
    firemaniac Well-Known Member
    Northwest corner of Montana, Troy/Yaak area
    04 DC 4x4, Flatbed, auto, teardrop tugboat.
    Flatbed, Bilstein/OME 883 lifted, ARB bumper, Warn M8000, Onboard air, Onboard water system, Lights, Lights, Lights
    I put a Koyo in my 04, back in 2019, and almost 20,000 miles ago, and I am happy with it. I have pulled my teardrop trailer throughout the summers, including PNW mountain passes in the heat of the day, and several forest roads for the Washington Backcountry Discovery Route while pulling the teardrop, and so far the only so called negatives I can find are the other modifications I had to make to the truck (that I planned on doing anyway, or had partially done already) for cooling the automatic transmission, as the Koyo doesn't have provisions for that.
  2. Aug 6, 2022 at 9:26 AM
    #762
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Hard to say when it failed exactly mileage-wise, but it lasted about 11 months. The warranty replacement is still going after 16 months, though (including two cross-country trips). Fingers crossed that it continues to hold up. I'll certainly post an update if it does fail.
  3. Aug 6, 2022 at 10:25 AM
    #763
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Im a year in (10K) on my champion in my 2rz........smooth sailing.
    BUT Im Rwd.....zero off road........
  4. Sep 30, 2022 at 8:46 AM
    #764
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    04Pre_Runner likes this.
  5. Sep 30, 2022 at 6:49 PM
    #765
    O'Silver_Taco
    MD
    I wonder if that is why the HOAt formula is giving some problems......
    ....you are always gonna get some current in any moving fluid......
    I swear, something is etching head gaskets........looking for a thief in the nite.....
    1997tacomav6[OP] likes this.
  6. Sep 30, 2022 at 8:21 PM
    #766
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  7. Sep 30, 2022 at 8:39 PM
    #767
    1997tacomav6
    Denver
    OEM radiators are made of plastic tanks, so don’t know.
  8. Sep 30, 2022 at 9:46 PM
    #768
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well seeing as to how literally all radiators are mounted with bolts on the wing sides which are all made of metal...
    i'd say you don't have to worry about it. 4 bolts into the side of the radiators. Means its grounded.
    Assuming that you actually have to even worry about that in the first place..
    MalinoisDad likes this.
  9. May 15, 2023 at 2:37 PM
    #769
    RattleTractor
    Harry
    VT
    Second Koyorad Racing radiator has failed. I guess I'll just go back to an OEM-level replacement and hope that the little diesel doesn't overheat.
  10. Jul 28, 2023 at 1:02 AM
    #770
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Jul 28, 2023 at 5:40 AM
    #771
    1997tacomav6
    Denver
    Actually looks good but who knows until the miles are driven,
    Might be a great choice!
    Looks a lot better than the champion.
    The champion radiator before gave up at 30k miles.
    If it’s a quality item the price is not bad,
    My custom radiator was over 1000.00 going strong zero issues with 75k on it and keeps
    the temperature around 170-180 regardless of outside summer heat
  12. Jul 28, 2023 at 11:12 AM
    #772
    Blackdawg
    Monte
    Wyoming/St. Louis
    CSF is a very very good reputable company. Should be miles better than the champion
