Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. May 8, 2018 at 9:25 PM
    #61
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Yes correct, but remember the methonal only sprays above 4.5 pounds of boost for me.
    I can drive all day sometimes and never get into the 4.5 boost area with the methonal if I drive easy. Supercharger only creates heat under boost
    Blackdawg[QUOTED] likes this.
  2. May 12, 2018 at 5:25 PM
    #62
    1HItaco
    1HItaco Well-Known Member
    idk how you guys are getting 22mpg.
    maybe i need to put supercharger.
    my V6 DC 04 4x4 averages 14MPG.......
    sucks
    maybe less throttle needed when cruising with supercharger and gives better fuel economy?
    burntkat likes this.
  3. May 12, 2018 at 5:34 PM
    #63
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I was able to get 20 from my double cab V6 on the highway. Even pretty loaded up and even with 33s.
    right up until i put the new offroad bumper on. Bye bye areodynamics.
    John is in a single cab with 250ish hp and almost 300ft/lb of torque with still 31s and strong bumpers.
    I get around 20mpg with my V6 single cab. Its great.
  4. May 12, 2018 at 6:12 PM
    #64
    1997tacomav6
    Denver
    The Volvo MAF mode definitely helped me gain a few extra miles per gallon.
    Today cruising at 65mph highway i was at 25 mpg.
    The supercharger actually moves the torque down to the 2000rmp range at max.
    At 2200rpms the superchargered engine is almost at max torque while the naturally aspirated motors torque is at 3600rpms.
    So with a few mods the supercharger is giving you an extra 100 hp and 100 torque
    so engine might be working less hard.
  5. May 20, 2018 at 2:25 AM
    #65
    1HItaco
    where can u learn about this volvo maf mod
  6. May 20, 2018 at 7:00 AM
    #66
    1997tacomav6
    Denver
  7. May 20, 2018 at 1:57 PM
    #67
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Has anyone done this on a 3RZ motor yet?
  8. Jun 2, 2018 at 8:32 PM
    #68
    1997tacomav6
    Denver
    Just an update on a number of questions from a bunch of Members PM included about access to the fan and belts etc.
    The 1st photo is with the new radiator installed without the shroud. At this point you have access
    to the fan, the fan clutch hoses and belts.
    The way the shroud is installed is as follows.
    The shroud has a lower section that clips on and off as shown
    in the BLUE color. This will let you slid the shroud with the radiator installed straight down (its tight)
    to be able to line up the bolt holes. The shroud is fat at the top, not at the bottom.
    After the shroud is attached with the 4 bolts you then attach the lower
    shroud trim piece(shown here in BLUE) that completes the round fan hole area using the 2 clips
    SilverGhost likes this.
  9. Jun 2, 2018 at 8:41 PM
    #69
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hell I bolted the shroud on first before installing the radiator. Had no issues.
    1997tacomav6[OP] likes this.
  10. Jun 2, 2018 at 8:57 PM
    #70
    1997tacomav6
    Denver
    Yup, there are a bunch of people that think you need to remove the radiator in order to get
    to the belts or fan if they need for maintenance. So they will know that you DONT need to and the shroud can be removed with the radiator staying in place if you
    needed to replace the fan,or fan clutch or fan support bearing.
  11. Jun 3, 2018 at 4:07 AM
    #71
    tony2018
    tony2018 Well-Known Member
    Truth, I'm able to replace belts w/o removing shroud or fan. Just maneuver it around the fan blades and BAAM done.beer.
    1997tacomav6[OP] and SilverGhost like this.
  12. Jun 3, 2018 at 5:23 AM
    #72
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Can I pick up the Stant 170* thermostat at any local auto supply store? I need to finally get this done. I’m running about 202 but I’ve seen it at 212
  13. Jun 3, 2018 at 6:18 AM
    #73
    1997tacomav6
    Denver
    That’s getting up there, Aluminum and heat = head gasket,
    Your going to love this swap performance and looks sooo good,
    I won’t worry about the 170 stat, the engines not going to stay at that temp anyway. But that’s my opinion.
    191 is my highest temp so far
    Average is 186-188
    QMEDJoe[QUOTED] likes this.
  14. Jun 4, 2018 at 3:39 AM
    #74
    QMEDJoe
    Joe
    Doing this today. Is there any benefit in flushing the system prior to changing the radiator? I’m thinking the benefit of flushing out any debris that may be in the engine.
  15. Jun 4, 2018 at 5:56 AM
    #75
    1997tacomav6
    Denver
    If you haven’t flushed in 50k would do it if your going in there
  16. Jun 4, 2018 at 6:10 AM
    #76
    tony2018
    Might as well...
    QMEDJoe likes this.
  17. Jun 4, 2018 at 6:39 AM
    #77
    1997tacomav6
    Denver
    Just a tip for you if u want, when you refill the radiator system,
    Fill the coolant first from the hose going into the top of the engine, bend the hose back turning it up at a 90 to 45 degress and fill it up.
    This way the water gets back in the block on the other side of the stat and then fill the radiator side. Less chance of overheating engine with no fluid in the block as the valve is closed till 180.
    Remember to burp the system as the top hoses for heater are higher than the top of the radiator.
    If you squeeze the top radiator hose hard and fast and hear sloshing coming from the heater
    inlet hoses by the fire wall then it still has air in the system.
  18. Jun 4, 2018 at 6:42 AM
    #78
    tony2018
    So rotate it 45 degrees upward so you can fill it with coolant, and to have it fill the block.
    QMEDJoe and 1997tacomav6[OP] like this.
  19. Jun 4, 2018 at 6:43 AM
    #79
    QMEDJoe
    Joe
    Thanks for the tip! I’ll be make sure to do just that. I watched a couple of videos and no one mentioned that one :thumbsup:
  20. Jun 4, 2018 at 6:44 AM
    #80
    1997tacomav6
    Denver
    Yup
    tony2018[QUOTED] likes this.
