Champion Radiator Aluminum 3 core swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 12, 2018.
HAS YOUR CHAMPION RADIATOR CORE FAILED?
  1. Radiator core failed 5k
    4 vote(s)
    10.8%
  2. Radiator core failed 10k
    4 vote(s)
    10.8%
  3. Radiator core failed 15k
    1 vote(s)
    2.7%
  4. Happy with radiator?
    18 vote(s)
    48.6%
  5. Radiator defect when new?
    5 vote(s)
    13.5%
  6. Radiator failed after 25k
    5 vote(s)
    13.5%
  1. Jun 4, 2018 at 6:46 AM
    #81
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Well if you think about it filling the radiator does NOT fill the block side up when completely empty because the stat is closed. It does leak in there slowly with the jigger valve
    QMEDJoe[QUOTED] likes this.
  2. Jun 4, 2018 at 6:52 AM
    #82
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Another question! Installing the new thermostat... Toyota says to install it one way but I’ve read that putting it in another way where the jiggle valve is facing 0600 or 1200? What have we found is the best way for cooling ?
  3. Jun 4, 2018 at 6:52 AM
    #83
    1997tacomav6
    Denver
    Install it at 6 o’clock
  4. Jun 4, 2018 at 6:57 AM
    #84
    1997tacomav6
    Denver
    Also if you have some silicone spray for the lower radiator hose to help get both ends to slide on will help. That hose is tough, the hose and the parts it slides on to
    are an 1/8” or 1/4” off in size, so its tight but will fit
    QMEDJoe likes this.
  5. Jun 4, 2018 at 9:12 AM
    #85
    QMEDJoe
    Joe
    Awesome, Thanks! I have some in the man cave :D
  6. Jun 4, 2018 at 9:13 AM
    #86
    1997tacomav6
    Denver
    If you use the compression fit hose clamps that are Toyota it'll definitely help get those on also
    QMEDJoe likes this.
  7. Jun 4, 2018 at 9:16 AM
    #87
    1997tacomav6
    Denver
    When you get to this point you'll understand 100% what's going on and what to do
    QMEDJoe likes this.
  8. Jun 4, 2018 at 1:42 PM
    #88
    QMEDJoe
    Joe
    How’d y’all remove the radiator? I’m dead aggravated right now. I watched a video of a guy with a 95 or a 98. It was 4 volts and he slid it up and out. Do I have to remove the grill and the brackets or am I missing something
  9. Jun 4, 2018 at 1:47 PM
    #89
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Remove the grill and the 4 bolts are easy to get to.
  10. Jun 4, 2018 at 1:49 PM
    #90
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    4 bolts on the front of the truck. You'll likely want to remove the grill to get to them.
  11. Jun 4, 2018 at 1:52 PM
    #91
    QMEDJoe
    Joe
    I got it out. Thanks.
    1997tacomav6[OP] likes this.
  12. Jun 4, 2018 at 7:49 PM
    #92
    QMEDJoe
    Joe
    I’ve got it all together. I noticed two fittings at the bottom as if to hook up some hoses like possibly for an automatic transmission cooler? (I have a manual) Do I need to cap those off or are those not in the same loop of coolant?
  13. Jun 4, 2018 at 7:50 PM
    #93
    1997tacomav6
    Denver
    Those are for the auto transmission, you don’t need to worry about them,
    You can cap them off if you want
  14. Jun 4, 2018 at 8:07 PM
    #94
    QMEDJoe
    Joe
    I don’t have any caps at this time. I was just worried about losing coolant all over my buddies driveway
  15. Jun 4, 2018 at 8:08 PM
    #95
    1997tacomav6
    Denver
    There is NO radiator coolant in there, those are for the transmission coolant to go in there if you have an auto, so automatic transmission fluid would go in the lower holes connected with the transmission lines
  16. Jun 4, 2018 at 8:32 PM
    #96
    QMEDJoe
    Joe
    That was my second guess. My first guess was they made two different radiators and they accidentally gave me an automatic. I then realized they more or less acted like a heat exchanger and we’re not in the same loop.
  17. Jun 4, 2018 at 8:34 PM
    #97
    1997tacomav6
    Denver
    Exactly, let us know your temp numbers before and after in a few days
  18. Jun 4, 2018 at 8:40 PM
    #98
    QMEDJoe
    Joe
    Will do. I’m suppose to drive to southern Louisiana tomorrow from Western NC. After filling her up I’m going to drive her around for a few hours and make sure she’s good before I make the long trip.
  19. Jun 5, 2018 at 11:13 AM
    #99
    QMEDJoe
    Joe
    All done with the install. Took her for a ride and she started to run hot. I let her cool off and she was low (must of hit an air pocket) topped her off and she’s running 186*-188*
  20. Jun 5, 2018 at 12:35 PM
    #100
    1997tacomav6
    Denver
    Nice temp change, it was 202 and 212?
    Now 188 that's a big drop in temperature make sure you get all the air otherwise it'll run hot
